October 10, 2010, 12:08 |
Fluent Error while running on cluster
Amool A Raina
Hi
I am trying to run a 3D fluent model on my school's cluster using FLUENT 12.1 However I am constantly getting a 'Stack backtrace error'. I did a bit or research and I found out that this is possibly caused due to memory allocation. Since I am using a script file and dont have access to the gui, I dont know how to fix this error. Anticipate a quick response. I am attaching the script file and the error log in case you need to take a look at them...thanks..aar |
October 22, 2010, 16:07 |
Basharat
have you configured your all nodes good ?
Rgds Martin |
October 23, 2010, 21:52 |
Amool A Raina
yes and I finally got it to work...but however I have one problem...my solution has a constant error of turbulent viscosity exceeded and also reversed flow. The reversed blow goes away after around 150 iterations but the turbulent viscosity seems to rise and eventually causes my solution to diverge...any comments on that are most welcome!
October 24, 2010, 01:48 |
Basharat
I am not mechanical engineering. but IT related person to resolve or help out within parallel computing over linux or windows.
Rgds Martin |
March 4, 2011, 02:58 |
#5 | |
So how did you manage the error? as i am still getting the error with 8 cores shared memory (same PC) |
March 4, 2011, 04:55 |
hi all
I am also having the same problem of stack error. I am attaching image file of that. Please suggest a solution for this. Regards |
script file for running fluent on linux cluster | Worth | FLUENT | 2 | February 9, 2012 11:31 |
Running fluent in UNIX | L3munoz | FLUENT | 10 | August 26, 2009 04:59 |
HELP: submitting FLUENT JOBS ON SGE CLUSTER | James Willie | FLUENT | 0 | January 27, 2006 05:42 |
Help please: submitting fluent jobs to sgi cluster | James Willie | FLUENT | 0 | January 27, 2006 05:38 |
Running FLUENT 6.0 sims. on FLUENT 6.1 | ozgur | FLUENT | 2 | April 2, 2004 13:23 |
