Help using DPM
Old   May 30, 2010, 00:23
Default Help using DPM
Eric
Eric1 is on a distinguished road
I am using DPM to see how long does the 1000 massless particles take to travel across my mixing tank. I am using unsteady particle tracking and track with fluid flow time step. I inject particle once at time 0, and I set max. number of steps to a very large number since I don't know how long it takes the particle to escape. However, when I start the simulation, once the at the first time step all the particles left already. That doesn't make sense, unless the particles travel the entire tank in 0.05s. I expect it should be around 300s. Can someone give me some advice?
Thanks,
Eric
Eric1 is offline   Reply With Quote
Old   May 30, 2010, 12:42
ali
alikami is on a distinguished road
I think calculate particle lag time to have an idea of time
alikami is offline   Reply With Quote
Old   January 27, 2011, 11:27
Renold is on a distinguished road
Thanks,
Eric
Hello Eric,
I wonder if you have solved this problem. I run into the same problem now.
Guangwei
Renold is offline   Reply With Quote
How to apply Transport Equation on DPM Scalars? yuhai FLUENT 0 May 19, 2010 10:38
DPM modeling Mohsin FLUENT 0 March 31, 2010 22:11
DPM - do the particles affect the liquid? Nikhil Dani FLUENT 0 January 1, 2009 11:58
slow after mesh for enhanced wall treat DPM joshkemp FLUENT 0 May 1, 2007 17:20
compatibity LES with DPM Alex Munoz FLUENT 0 March 26, 2003 21:13
