meshing and boundary condition
Old   January 31, 2011, 13:40
no183
no183 is on a distinguished road
huh? bro, why? sorry a stupid question
no183 is offline   Reply With Quote
Old   February 1, 2011, 00:54
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
because you don't need those volumes.
They are isolated volumes without any fluid-connection to your computationnal domain.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 4, 2011, 10:11
no183
oh sorry heading for my CNY holiday, get to work. now i know, i deleted it, can i start meshing?
Old   February 8, 2011, 06:31
no183
? are u there bro?
Old   February 8, 2011, 07:32
-mAx-'s Avatar
Maxime Perelli
yes you can
Old   February 9, 2011, 08:07
no183
ok, i meshed it.. Unfortunately, it caused me around 30 minutes, and this time, all the result i save for u to analyse. i get some of the meaning, but some not. Guide me thanks
Old   February 9, 2011, 08:18
-mAx-'s Avatar
Maxime Perelli
Examine face face.3086, you will see that skewed cells are linked with topology "issue" like sharge angle etc...
Use merge tools for fixing this problem.
Then same thing with face face.2557, etc....
But as I already told you, I would FIRST try to mesh your domain without all your fans, which will give your lots of "clean-up" work
Old   February 9, 2011, 08:36
no183
How to mesh domain without fan? i using mesh volume feature which select all volume at once?
Old   February 9, 2011, 08:40
-mAx-'s Avatar
Maxime Perelli
when you started with import: delete fan's volumes before substracting
Old   February 9, 2011, 08:44
no183
hmm, ok forget about deleting the fan volume first, i will try with examine face, for examine face, what shud i do? where is the examine face button?
Old   February 9, 2011, 08:51
-mAx-'s Avatar
Maxime Perelli
direct above your windows clock
Old   February 9, 2011, 08:56
no183
That is examine mesh, fine. now i press it. Where to edit so that i can examine face 3086? This is the place where only i can see the quality of the mesh.
Old   February 9, 2011, 09:15
-mAx-'s Avatar
Maxime Perelli
go to range
select all kind of elements (hexa/pyramid/wedge/tetra)
set lower limit to 0.9
set upper limit to 1
and display...
all the displayed element should be fixed (especially elements between 0.95 and 1)
Then check where are the cells, they should be focused at one topology "issue" like sharp edge etc...
Then exit to the examine panel, et display the surfaces where Gambit failed to mes the surfaces. You should recongnize the topology "issues"...
Old   February 9, 2011, 09:21
no183
i presume i done it correctly? but why when i press update, it will reset back lower and upper limit 0 and 1 with no element in there? NOTE THAT i already change the lower and upper limit as u say
Old   February 9, 2011, 09:40
-mAx-'s Avatar
Maxime Perelli
your volume mesh failed, that's why you cannot see any volume elements (because you don't have any)
do the same but with 2d elements
Old   February 9, 2011, 09:52
no183
wow, can i did this while i off mesh in display attribute? cause it is annoying freaking long just to see it. and i cant rotate the screen(left click turn) as all hang started again
Old   February 9, 2011, 10:00
-mAx-'s Avatar
Maxime Perelli
with 2 elements, it shouldn't be slow.
With 10miilions volume elements, then yes, you can pray that your session won't crash.
Old   February 9, 2011, 10:10
no183
ya, finnaly at the end, i am NOT able to see it. i will consider removing the fan volume again then if that is the only idea
Old   February 23, 2011, 09:43
no183
hey, i am back, remeber last time i say i want to remove the fan, i did it. and here is the summary.
I import the STP file and delete the fan partition.
Then unite whole volume, subtract it to get fluid domain.
Then i mesh using "Mesh Volume" with spacing of 1. Fortunately, 1 equisized skew issue only comes out. But, mesh fail and the transcript state that due to face 43, asking me to mesh face 43 using the "Mesh face" function(i guess i correctly digested the meaning?)
Then i do face meshing at face 43, here is the result
i am running out of idea now. What should i do?
Old   February 24, 2011, 03:30
-mAx-'s Avatar
Maxime Perelli
you are trying to mesh your face (complex one) with quad.
Forget trying to mesh your volume with hexa.
Switch with tetra (tri for surface mesh)
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 prashanthreddyh ANSYS Meshing & Geometry 1 December 20, 2011 00:35
Boundary layer meshing problem in Gambit Crystal FLUENT 0 June 12, 2009 20:58
GAMBIT problem with 3D Boundary Layer when meshing Anthony Haroutunian FLUENT 2 March 26, 2008 02:02
Help Urgent about changing boundary condition Anjum Naveed FLUENT 7 August 14, 2006 12:25
Boundary Layer Meshing of a nosecone Chris FLUENT 1 March 15, 2005 12:42
