coupling population balance with reaction
Like Tree1Likes
  • 1 Post By mehdi kamyabi
Old   November 7, 2010, 10:52
Default coupling population balance with reaction
mehdi
mehdi kamyabi is on a distinguished road
Dear all
Hello
I want to ask if I can couple a precipitation reaction with population balance method in the FLUENT? if possible,please help me and answer this questions:
1- I need to active multiphase mood for modeling the precipitation population reaction that happens in a primary liquid phase? am I right? ( two reactant in the liquid phase makes a precipitate)
2- if yes how I can couple it with population balance? ( the problem is when I active multiphase I can not choose eddy-dissipation method from reaction methods)
Best Regards
ashar_md2001 likes this.
mehdi kamyabi is offline   Reply With Quote
Old   June 3, 2011, 06:29
Default Population balnce modelling
Mohamed Ashar
ashar_md2001 is on a distinguished road
hello ,
I am new to population balance modelling of preciptation of barium sulphate
.i.e. Bacl2+Na2So4------»BaSO4
I need to do PBM using Fluent can you please guide me with it like for example the datas and properties we require for simulation etc. and How to go about with the simulation. This is done in Reactor where two reactant will be fed through the two different inlet and impinge in the center.
You help will be highly appreciated.
Regards
Originally Posted by mehdi kamyabi View Post
Dear all
Hello
Best Regards
ashar_md2001 is offline   Reply With Quote
Old   April 29, 2013, 13:36
Mohamed Ashar
Hi Mehdi,
I am working on similar problem precipitation reaction Bacl2 (r)+Na2So4 (r)------»BaSO4 (Product). Did you find out how to go about the problem. You help will be highly appreciated.
Regards
Ashar
Old   May 3, 2013, 07:33
mehdi
Dear ashar
it is long time i didn't use cfx and population balance also.
but if you ask your questions more clearly and specify what do you want to know exactly maybe i can help more.
Old   May 3, 2013, 12:51
Default PBM modelling
Mohamed Ashar
Dear Mehdi,
Since in my case the BaSO4 crystals is the secondary phase, in the inlet B.C. for phase 2 volume fraction should be zero right? and should I define the volume fraction 1 in the outlet B.C for secondary phase?
Please can you guide me. thanks
Old   August 26, 2013, 15:13
Default regarding material creation
Hem
hem233 is on a distinguished road
Hello everyone,
I am having a problem creating materials.. In my case i have a reaction like BaCl2 + H2SO4 = BaSO4 + 2HCl.. where BaCl2 and H2SO4 are aqueous solution of certain concentration and BaSO4 is a solid crystal.. So while i am defining BaCl2 under solid it is showing me error. Also i dont know how to make it a aqeous solution.. Also if I define it anyway,, it is not showing under phases...
And if i define it as a fluid, then also it requires viscosity of BaCl2 and BaSO4 which I could not able to find...
So,, if you have any kind of idea how to move forward please reply soon....
hem233 is offline   Reply With Quote
Old   August 28, 2013, 10:05
Default email me
Mohamed Ashar
send me a msg @ ashar_md2001@yahoo.com to discuss because I rarely login here.
Old   December 5, 2015, 01:14
wubin
Athena is on a distinguished road
Originally Posted by ashar_md2001 View Post
Hi Mehdi,
Regards
Ashar
Hellow, I am doing the similar working as you. Have you meet the question about how to add correction term when using QMOM model?
Athena is offline   Reply With Quote
coupling reaction with population blance method mehdi kamyabi Main CFD Forum 0 November 7, 2010 06:51
Population balance for airlift reactor amira FLUENT 2 January 28, 2010 02:04
Population balance for airlift reactor (FLUENT) amira Main CFD Forum 1 October 31, 2009 07:54
Population Balance Theory student Main CFD Forum 2 August 10, 2008 04:12
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
