moving mesh rolling piston
Old   November 5, 2010, 12:04
Default moving mesh rolling piston
JohannVV is on a distinguished road
hi all.
i'm simulating a rolling piston with a moving mesh.
I use the remesh method . the setings for the walls of the slider which is directly connected to the piston are; deforming.
the piston motion is defined by a udf.
the main problem is that the simulation takes some iterations, but then accurs an arror.
the error at the calculation process is: Divergence detected at AMG-Solver
and the error at the preview mesh motion is: negative cell volumen detected.
do some one has a hint, what is wrong
JohannVV is offline   Reply With Quote
Old   November 6, 2010, 15:51
Arash
arash_7444 is on a distinguished road
I think It's because of poor quality of your meshes. try to improve it, it might help
arash_7444 is offline   Reply With Quote
Old   November 7, 2010, 17:31
Hi arash_7444 thank you for reply.
I dont think that the problem is because of poor mesh quality, but in any case I will check it tomorrow.
what i not understand is: why the calculation of the case takes some iterations an then the error eccurs. schould the mesh not be remeshed if the maximum scew gous over the maximum scew factor?
Old   November 8, 2010, 02:21
hi arash_7444, I just checked the mesh quality and the error is the same .
may you have any other hints, how to solve this problem. thank's in andvance.
Old   November 11, 2010, 09:46
i solved the problem. the slider and the rotary pistow were connected, but this is not allowed if the piston is a rigid body.
Dynamic Mesh moving interface help akash.iitb FLUENT 0 August 23, 2010 23:53
VOF with a moving mesh Jeremie FLUENT 1 November 26, 2008 08:55
moving mesh in parallel mode Karteek Siemens 4 June 16, 2008 04:12
CavitatingFoam with a moving mesh mass conservation error idosil OpenFOAM Running, Solving & CFD 3 November 27, 2007 17:27
Moving Mesh and MRF Romain FLUENT 1 May 16, 2002 03:45
