2 inlets, 2 UDF
Old   July 13, 2010, 05:28
Default 2 inlets, 2 UDF
bilalmerei
bilalmerei is on a distinguished road
plz i need an urgent help.
i have to inject oil into water.
the problem that water must have a specific profile of velocity so i have to introduce a UDF. and same for the oil.
so i don't know how to define 2 UDF and interpret them in each inlet.
plz help
bilalmerei is offline   Reply With Quote
Old   December 12, 2010, 13:26
Question UDF needed too
Rajat
rajat4416 is on a distinguished road
I too need udf function for a fully developed velocity profile at inlet in vertical channel . As i have never worked on Fluent i dont know how udf
have to write is it exactly the same code as in FORTRAN or C as i know
both well but udf i dont know
rajat4416 is offline   Reply With Quote
Old   December 12, 2010, 13:54
Real Name :)
ComputerGuy is on a distinguished road
UDF's are User Defined Functions
They are typically written in C, but can be written in Fortran. Fluent has a C interpreter built in, so you don't need one unless aspects of the calculation (specific Fluent calls, speed of calculation, etc) require compilation.
To impose a fully developed profile at a wall, you must loop over all faces of the wall and set the velocity magnitude (or, perhaps, a vector component) equal to the velocity you obtain from fully developed flow.
In the code below, I assume the following:
1) Fully developed laminar flow
2) 2-D flow in the x-direction
3) An inlet face which extends from 0.5 to -0.5 in the y-direction
4) A maximum centerline velocity of 10
#include "udf.h"
DEFINE_PROFILE(inlet_x_velocity, thread, position)
  real x[ND_ND];                /* this will hold the position vector */
  real y;
  face_t f;
  begin_f_loop(f, thread)
      F_CENTROID(x,f,thread);
      y = x[1];
      F_PROFILE(f, thread, position) = 10.-10.*(y*y/(0.5*0.5));
  end_f_loop(f, thread)
I haven't tested it, but it should function OK with few, if any, changes. I don't know which direction you've specified as vertical, so you'll need to adapt a few things in the code above to fit your application.
Go here: http://combust.hit.edu.cn:8080/fluen.../udf/node2.htm
for more information on UDFs.
ComputerGuy
ComputerGuy is offline   Reply With Quote
Old   December 13, 2010, 02:04
Smile Thanks
Rajat
many thanks to ComputerGuy for you help and code I will try to learn and do whatever is needed furthermore.
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
udf for velocity profile in a geometry having two inlets shubham208011 Fluent UDF and Scheme Programming 0 April 6, 2009 15:13
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
