Help with Meshing
Old   December 15, 2010, 22:58
Default Help with Meshing
Ankur Mour
Ankur is on a distinguished road
I am trying to model the air flow in a torrefaction chamber and I would be glad of any assistance.
This is the Geometry of the Chamber that I am trying to model. As you can see there are two rectangular boxes - one inside the other.
The external box has three circular pressure outlets for the air to be sucked out.
The inner box has a rectangular face at the front, as a velocity inlet for the air to come in.
The top of the inner box has plenty of holes for the air to enter the outer box from the inner box. (Like a zero thickness perforated sheet)
What i want to know is what boundary type do I denote the top of the inner box and the holes as?
Thanks a lot
Ankur is offline   Reply With Quote
Old   December 18, 2010, 12:09
Sowmya K
skris2009 is on a distinguished road
It looks like the top of the inner box has too many holes and it might not be feasible to give boundary conditions to each of these holds. You could try the porous boundary condition in Fluent. It allows you to specify a porosity and a thickness of a material.
I used this BC for a similar problem once, and I didnt know the porosity of the material I was using, but I knew that air was flowing easily through the material. So I assumed a very thin material of porosity comparable to cotton cloth.
If you can get a porosity for your material then great. If not, you can approximate it depending on the physics of the flow through the material.
Hope this helps.
skris2009 is offline   Reply With Quote
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 01:09
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 05:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
