Temperature distribution for gas turbine inlet conditions
Old   February 19, 2012, 08:27
Unhappy Temperature distribution for gas turbine inlet conditions
PB
Aerogirl is on a distinguished road
Hi all,
Is anyone aware of a way that I can model a region of high temperature at the inlet face of my gas turbine blade simulation?
I have a sliding mesh simulation with a stator in front of a rotor and would like to vary the temperature gradient on the inlet flow at the stator to see the effect that it will have on the blades.
Ideally I am looking to simulate a region in the centre of my square inlet face that is hotter than the surroundings as in gas turbines there is typically a variation in the temperature gradient as the hot gas hits the blades.
I have googled only to find a very complex C++ programing method and I feel this is too advanced for what I need to do.
Any suggestions will be greatly appreciated
AeroGirl.
Aerogirl is offline   Reply With Quote
Old   February 19, 2012, 15:20
Default UDF temperature profile
PB
Hi all,
As I am modeling the flowpath in 3D I assume I need a 3D code so I wrote one. It doesnt seem to be working however and I am sure it is because I have not defined my variables correctly. I simply want the flow in the middle of the square inlet to be hotter than that of the outside so I am not even sure if I need the additional z variable. The middle of the rectangle lies at (0,0.365) I am getting divergence because of f when I try to run it in FLUENT. It is as follows:
#include "udf.h"
DEFINE_PROFILE(inlet_temp, t, i)
real x[ND_ND];
real y;
real z;
face_t f;
begin_f_loop(f, t)
F_CENTROID(x,f,t);
y = x[1];
z = x[2];
F_PROFILE(f, t, i) = 124.-0.365*0.365/(0.035*0.035)*124.;
end_f_loop(f, thread)
Thanks in advance,
AeroGirl
gas turbine, inlet, temperature distribution, temperature gradient
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
inlet boundary conditions mattia Main CFD Forum 0 February 11, 2009 06:06
Inlet boundary conditions Mattia CFX 0 February 9, 2009 13:25
High temperature methane+air Peter FLUENT 5 January 26, 2009 18:04
Velocity Inlet Boundary Conditions M.A. Rakib FLUENT 3 June 7, 2000 09:40
