Two-phase DPM
Old   January 10, 2011, 01:25
Default Two-phase DPM
viva
viva is on a distinguished road
Hi:
I want to simulate gas+particle flow in a pipe. In that case do we need to select the Eulerian model from the multiphase (for the gas phase) and DPM for the solid phase.
Thanks
viva is offline   Reply With Quote
Old   January 10, 2011, 03:03
zhao peng
zhaopeng is on a distinguished road
you need not to select any multiphase model, DPM model is appropriate for your case.
zhaopeng is offline   Reply With Quote
Old   January 10, 2011, 11:49
viva
Thanks Zhao:
In that case where are we giving the velocity for the gas phase and how do we get the profiles of the gas phase? In the contours it does not give any option for the gas or solid phase. The phase option is also off in the problem setup panel if we just select DPM.
Thanks
Old   January 11, 2011, 08:31
zhao peng
DPM model cannot give you the velocity distribution of solid phase by "Display Contours”, but it can display the particles pathlines color by velocity magnitude in "Display Pathlines".If you want to know the variables distribution of different phase, you can try to switch to Eulerian model or Mixture model.
Gas phase velocity in DPM Drag UDF Hanz Fluent UDF and Scheme Programming 0 June 2, 2009 14:08
Discrete Phase Model and DPM Concentration Zach FLUENT 1 March 10, 2009 15:36
The minimum diameter of second phase in the DPM Fluenter FLUENT 2 August 15, 2004 06:46
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
steady or unsteady? (in dpm) winnie FLUENT 1 April 28, 2003 11:30
