Floating point exception during parallel mode of fluent
Like Tree9Likes
  • 2 Post By Shamoon Jamshed
  • 7 Post By victoryv
Old   January 11, 2011, 07:01
Question Floating point exception during parallel mode of fluent
Aamer Shahzad
aamer is on a distinguished road
Dear all
i am doing simulation on 3 D wing which is having 6.5 million cells. my OS is windows 7 64 bit with 8 gb RAM and 8 cores (i am using 64 bit version of fluent). when i run the case by using 4 cores of the computer (i.e by starting fluent with command fluent 3d -t4) i get error as "primitive error at node 1, node 2 and node 3: floating point exception" after few iterations. As remedial measure i reduced my under relaxation factor and time step but the problem remained the same......
when i run the same case with single processor, the case is running okie under same settings. In order to save the computational time i have to exploit parallelism, i am trying to resolve this issue...... any body having any idea why this error is coming with parallel mode????
aamer is offline   Reply With Quote
Old   March 5, 2011, 05:45
Smile
mohammad
mohammad is on a distinguished road
Originally Posted by aamer View Post
Dear all
Hi Aamer, I'm not going to answer your quesetion, rather to ask you a question.
I have a 4-core computer and I want to use Ansys11 on windows7( 64bit)..is it possible? I will be really thankful if you can help me?
mohammad is offline   Reply With Quote
Old   March 5, 2011, 11:43
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Hello Mohammad and Amir
@Amir : I must say that your error appears because of divergence. Actually what Fluent does is that it divided your comp. domain to all the cores or (nodes) in case of more than one PC. And when divergence appears with minor error the data that is shared b/w the cores also bulges out. This gets handled very easily in case of shared cores in single PC where delay time is negligible b/w cores. May be you get divergence after some more time as compared to distributed parallel. Try to use Density based solver with low CFL at first.
* Shared parallel : Same pc and parallelism is between cores
** Distributed parallel : Different (more than one) PC and parallelism between nodes (containing multiple cores)
@ Muhammad : Better to check compatibilty on ANSYS website, you should shift to version 12 I think cos ANSYS 11 came prior to Windows 7.
pezarello86 and jzc like this.
Shamoon Jamshed is offline   Reply With Quote
Old   February 7, 2012, 22:55
Default Floating point error :invalid number
sheikh nasir is on a distinguished road
Hello.
I am getting floating point error in my thesis ie the train moving through tunnel. Can any body help me. My email is
sheikhnasir39@gmail.com
please help me
thanks
sheikh nasir is offline   Reply With Quote
Old   September 8, 2012, 00:51
Default Floating point exception during parallel mode of fluent
Amir Hossein Ahmadi Motlagh
ahmadimo is on a distinguished road
Dear all
Hi aamer,
I am now having the same issue getting floating point errors when using SMP with 8 cores. However, things are going well when running with single processor. I was wondering if you had any progress on this issue or anybody else could help me with it.
I am modeling an Eulerian-Eulerian gas-solid fluidized bed. The approach proposed by Shamon Jamshed does not work for me as I am not allowed to use density-based solver with MultiPhase models in Fluent.
Regards,
Amir
ahmadimo is offline   Reply With Quote
Old   October 30, 2012, 19:14
victoryv is on a distinguished road
I don't know if this information helps you or not. I was getting the same error. I reduced the relaxation factors as I assumed it was due to divergence. It worked perfect. Btw, I was also running in parallel.
lamboram, czhao86, Mazur and 4 others like this.
victoryv is offline   Reply With Quote
Old   May 8, 2013, 04:47
will chen
mypergrfr is on a distinguished road
Exactly, I get a convergence result by using your solution. But why this happens?
mypergrfr is offline   Reply With Quote
Old   November 30, 2013, 13:35
jipaz is on a distinguished road
What parameters should I reduce relaxation factor and until what values?
Thanks in advance
jipaz is offline   Reply With Quote
Old   December 1, 2013, 22:00
will chen
Thanks in advance
It depends on which solving method you are using,and which problem you are solving. I am using the coupled method to solve the natural convection problem. I changed all there under-relaxation factors from 1 to 0.3.
Regards.
Old   August 19, 2015, 04:56
Mina
Mina_Mbg is on a distinguished road
I have the same error
Could you tell me which relaxation factors?
Explicit relaxation factors
or
Under-relaxation factors
Mina_Mbg is offline   Reply With Quote
Old   May 16, 2019, 09:49
esha is on a distinguished road
I also have the same error for viscoelastic flow over a 2D cylinder. I have changed methods, values of relaxation factors and even refined my mesh. but I do not have a solution. can anyone suggest what should I do? for simple laminar flow over the cylinder, it worked well.
esha is offline   Reply With Quote
reactingFoam floating point exception pajofego OpenFOAM 0 November 6, 2010 17:29
Floating point exception gareth__it_power OpenFOAM Running, Solving & CFD 2 February 16, 2009 12:55
Unable to start fluent in parallel mode Anand FLUENT 1 January 11, 2009 16:48
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
floating point exception (underflow) Prashant Main CFD Forum 0 December 17, 2004 01:54
