flow depth in 2D open channel ?
Old   November 20, 2007, 12:18
Default flow depth in 2D open channel ?
rodi
Hi ! I am working in a 2D open channel with VOF,two phase:air /water.The flow depth at the inlet is specialed ,and I get the free surface ,but how to compute the flow depth at outlet? Just multiply Area by volume fraction of water?
Thanks! rodi
Old   November 20, 2007, 12:56
Default Re: flow depth in 2D open channel ?
bohis
Hi, you donīt need to set the depth of water at a outlet. You should only patch the domain according to the physics and adjust the correct backflow at the outlet.
Enjoy your calculation
bye, Jan
Old   November 21, 2007, 03:42
rodi
Thank you! Maybe i can express my question much clearly~
When the caculation has done,and i got the free surface.During the postprocessing,I want to know the water level at the outlet,what can i do? For 2D simulation,the channel is rectangle. Can i just multiple the water phase fraction by the area of outlet?
Thanks! rodi
Old   November 21, 2007, 11:34
k.baker
dear rodi you can find the height of water at the outlet from the value of vof at outlet directly by trial and error from the following relation: RL=(1/pi)*(pi-acos(2*(hL/d)-1)+(2*(hL/d)*SQRT(1-(2*(hL/d)^2))
where RL is the vof of liquid (water) & hL is liquid height
I hope this fullfill your request another thing I sent you two emails envolve some questions about your case file which you sent me did you see it or no? did you see my case & data file too? hope to see your reply soon
cheers kb
Old   November 22, 2007, 00:04
sushii
What is Backflow....and how dose it affects the calculations...? Sometimes when simulating I set backflow volume fraction and backflow turbulent KE....to zero...does it affect the solution...? if yes then how to calculate right backflow volume fraction and turbulent KE...?
---Sushii..
Old   December 2, 2010, 00:02
Default Open Channel Flow boundary conditions
rahulrp is on a distinguished road
Originally Posted by rodi
;146875
Thanks! rodi
HI,
I am Rahul. I am also working on Open Channel Flow in Fluent solver. I used
Mass Flow Inlet bc
mass flow of air is 7985.6 kg/s, free surface of water is at 2m, bottom at 0m,
Pressure Outlet bc
In my case the, the channel is rectangular of cross section 4mx3m. Out of 3m height upto 2m there is water. Now I really dont understand what boundary condition should I use for remaining 1m. The geometry is attached herewith.
One more thing to be discussed is that, should I patched volume fraction of water( secondary phase) initially through out the domain. I am trying for steady state simulation.
If somebody have a test case for open channel flow pls do send me on praghanmor@gmail.com
Hoping for ur fruitful suggestions.
Thanks.
rahulrp is offline   Reply With Quote
Old   January 25, 2011, 10:03
darp is on a distinguished road
Hi rahulrp
what does your mesh look like?
darp
darp is offline   Reply With Quote
Old   January 25, 2011, 23:03
vig
anonymous
vig is on a distinguished road
I you take mass flow inlet boundary for open channel, then both water and air can enter from the same.
Specify free surface level
Specify bottom level
Specify mass flow rate of water as = rho_water *Area_water*Velocity
Specify mass flow rate of air as = rho_air* Area_Air * Velocity
You can use the same velocity for both water and air.
vig is offline   Reply With Quote
Boundary condition problem for open channel flow Andy CFX 9 June 11, 2016 07:20
Open Channel Flow ElanMorin FLUENT 4 February 25, 2015 16:26
how to use Up Stream boundary condition in open channel Flow ms.jafarinik FLUENT 0 April 18, 2010 14:38
Open Channel flow Boundary khalid FLUENT 1 November 4, 2006 11:53
SIMPLE Scheme for open channel flow ao Main CFD Forum 0 April 6, 2004 16:21
