February 15, 2011, 03:27 |
heat flux balance problem
Zhou Xu
Rep Power: 15 |
I want to simulate the heat transfer through a window placed between indoor and outdoor environmental conditions. After several failures, I reduce my model to just a rectangular that represents the window glass. I define constant temperature walls for the two glass surfaces, and the top and bottom walls are adiabatic. But the heat transfer through the two surfaces are still not in balance, e.g., -116 W for the hot surface and 150 W for the cold surface. I searched through the forum. Actually people had posted similar questions before, but no one had ever replied. Please help! |
February 15, 2011, 05:36 |
Rep Power: 17 |
chk this link: http://www.philonnet.gr/downloads/an...s_tutorial.pdf
It shows procedure to solve ur problem. Also if all you are solving is conduction in the glass by giving BCs across the two surface I hardly see the need to use FLUENT for the simulation. |
February 15, 2011, 06:30 |
thanks
Zhou Xu
Rep Power: 15 |
Eventually I want to simulate double glazing with frame and spacer, so there will be convection and radiation in the glazing and frame cavities.
I've read the link document. I don't see how it solves my problem. It doesn't mention the inconsistency of the heat flux through the two surfaces. |
February 15, 2011, 07:10 |
Rep Power: 17 |
Note the convergence criterion:
convergence criterion of 1.0e-10 U never mentioned what was your criterion for convergence. Also try with finer grids. Also note the following remark: Difficulty in obtaining convergence or poor accuracy may result if input values are used outside the upper and lower limits suggested in the problem overview. |
February 17, 2011, 03:57 |
Zhou Xu
Rep Power: 15 |
After 14500 interations, the energy residual remains stable around 1e-7, and the continuity residual is 1e-5. The heat balance is almost achieved.
What do you think of the residuals? Should I run more interations? or change the pressure or momentum to second order? |
May 21, 2014, 03:37 |
cfx radiation_model wall heat flux imbalance
Rep Power: 12 |
when i use three plate (between the plate, there is air.) to calculate radiation between the plate,the left plate is high temperature plate,the right plate is low temperature ,i find that wall heat flux is imbalance in different surface,that is, the wall heat flux in the left plate ,the media plate and the right plate don't agree to each other
and the radiation model is DT(Surface to Surface). anyone can give me a help? thx!!! |
heat transfer balance |
problem with constant wall heat flux | openfoam1 | OpenFOAM | 6 | January 13, 2019 08:18 |
HTC/Wall Heat Flux monitoring in 12.1 | Michael.J | CFX | 4 | June 10, 2010 08:36 |
Heat flux in ansys cfx | juliom | OpenFOAM Running, Solving & CFD | 2 | April 14, 2009 14:30 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
WALL HEAT FLUX V.S. HEAT FLUX | tommy | CFX | 0 | December 15, 2005 08:14 |
