Rep Power: 15 ![]() |
Hi everyone !
I am modeling a surface reaction at the walls of a channel. I disabled the "heat of surface reaction" in the species menu and I set adiabatic boundary condition along the channel, so that the temperature should be determined only by the inlet temperature. I use the default Arrhenius reaction rate constant but the reaction rate does not show any temperature dependence as would be expected: the species concentrations along the channel remain the same, whatever inlet temperature I use. Moreover, the temperature does change and follow an exponential profile similar to that of the species along the channel. Hence my question: why ? It does make sense to me and I guess there is something wrong in my settings but I cant see what... If you have any suggestion, please do share it ! Thanks a lot ! PS: i even set all the enthalpies to 0 to check if fluent was considering them but this did not change the results. |
the activation energy was too low.... hence the weak temperature-dependence.
reaction rate, surface reaction, temperature dependence |
Segmentation fault in running alternateSteadyReactingFoam,why? | NewKid | OpenFOAM | 18 | January 20, 2011 16:55 |
surface reaction rate with udf | yellow-stuff | FLUENT | 4 | January 29, 2010 12:53 |
UDF changing the rate exponent of a reaction | Stefan H | Fluent UDF and Scheme Programming | 0 | September 16, 2009 13:20 |
Surface reaction rate | Jon | FLUENT | 5 | December 19, 2007 07:01 |
surface reaction | Jason | FLUENT | 0 | September 26, 2003 12:29 |
