Surface reaction rate temperature dependence
Old   February 15, 2011, 10:00
Default Surface reaction rate temperature dependence
tumbao is on a distinguished road
Hi everyone !
I am modeling a surface reaction at the walls of a channel. I disabled the "heat of surface reaction" in the species menu and I set adiabatic boundary condition along the channel, so that the temperature should be determined only by the inlet temperature. I use the default Arrhenius reaction rate constant but the reaction rate does not show any temperature dependence as would be expected: the species concentrations along the channel remain the same, whatever inlet temperature I use. Moreover, the temperature does change and follow an exponential profile similar to that of the species along the channel.
Hence my question: why ? It does make sense to me and I guess there is something wrong in my settings but I cant see what...
If you have any suggestion, please do share it !
Thanks a lot !
PS: i even set all the enthalpies to 0 to check if fluent was considering them but this did not change the results.
tumbao is offline   Reply With Quote
Old   February 17, 2011, 09:14
Default problem solved....
the activation energy was too low.... hence the weak temperature-dependence.
reaction rate, surface reaction, temperature dependence
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 16:55
surface reaction rate with udf yellow-stuff FLUENT 4 January 29, 2010 12:53
UDF changing the rate exponent of a reaction Stefan H Fluent UDF and Scheme Programming 0 September 16, 2009 13:20
Surface reaction rate Jon FLUENT 5 December 19, 2007 07:01
surface reaction Jason FLUENT 0 September 26, 2003 12:29
