February 28, 2011, 03:40 |
small doubt with fluent
iņigo
Hello. I am working in the simulation of a ductile iron cube submerged in a molten salt bath.
Obviously, the cube and the salt bath are at different temperatures, but I can't figure out how could I implement it; if I use the 'initialize' command, the two volumes are at the same temperature, and using the 'boundary conditions' command doesn't help either, because it only puts the wall at the requested temperature (as expected). So, my question is: is there any way to impose two different temperatures to two volumes before starting the simulation? Thanks in advance |
February 28, 2011, 11:36 |
Diego Simón Davila
I've made a little video for you:
http://www.youtube.com/watch?v=iK3gShc_wsY I've patched using a register, but if the cells you want to patch are in a different volume zone, you can better use that (check the Patch window). Cheers |
February 28, 2011, 13:04 |
iņigo
Thank you!that works wonders
Fluent - license problem. | Marcin | FLUENT | 3 | April 13, 2018 16:33 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 02:44 |
Fluent 6.3.26 vs 12.1 and partition method | Anorky | FLUENT | 0 | April 27, 2010 10:55 |
doubt on Patch option in FLUENT | raghav | FLUENT | 0 | November 4, 2008 22:33 |
