Parralel procesing: udf library does not load.
Old   March 6, 2011, 09:55
Default Parralel procesing: udf library does not load.
Faraj
Filankes is on a distinguished road
Opening library "libudf"...
Primitive Error at Node 0: open_udf_library: successfull
Primitive Error at Node 1: open_udf_library: system cannot find the specified folder
Primitive Error at Node 2: open_udf_library: system cannot find the specified folder
Error: open_udf_library: successfull
Error Object: #f
Primitive Error at Node 3: open_udf_library: system cannot find the specified folder
Primitive Error at Node 4: open_udf_library: system cannot find the specified folder
Primitive Error at Node 5: open_udf_library: system cannot find the specified folder
Primitive Error at Node 6: open_udf_library: system cannot find the specified folder
Primitive Error at Node 7: open_udf_library: system cannot find the specified folder
Filankes is offline   Reply With Quote
problem loading UDF library in parallel cluster Veera Gutti FLUENT 8 July 26, 2016 07:24
failing to load a UDF IvanCFD Fluent UDF and Scheme Programming 13 January 20, 2012 15:17
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 10:16
Error in opening the UDF library Sri FLUENT 3 December 11, 2006 16:19
