March 1, 2011, 15:19 |
Grid/Mesh Import
David
Rep Power: 15 |
All,
I am having problems importing a mesh (.cas) file into FLUENT4. The mesh is a solely tetrahedral mesh. The error I get is below: > Reading "\"| utility fl42seg \\\"CubeTest.fluent.cas\\\"\""... Starting /usr/local/fluent/x86_64/v120/fluent/utility/fl42seg1.3/lnamd64/fl42seg.1.3.2 CubeTest.fluent.cas FILE MARKER #!fluent.1 NOT FOUND. CubeTest.fluent.cas IS NOT A VALID ERROR: INVALID MESH Building... mesh Error: Null Domain Pointer Error Object: #f Any ideas on what the problem could be--what the missing "file marker" is? Yours, |
[ICEM] Import geometry from solidworks | holyo | ANSYS Meshing & Geometry | 11 | April 16, 2014 11:47 |
How to import NACA 0012 Profile in Gridgen | maplepink | Main CFD Forum | 17 | May 7, 2013 13:01 |
mesh missing after import in fluent | morteza08 | FLUENT | 0 | July 23, 2010 02:22 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
import mesh problem | Wendy | CFX | 2 | February 6, 2002 05:39 |
