Rotation of Can
Old   March 10, 2011, 03:58
Smile Rotation of Can
Narayansing
chhanwal is on a distinguished road
i am using Ansys12-fluent
i am working on rotation of cylindrical can.
when i give rotation with moving mesh in cell zone condition and set rpm and same follow in boundary condition, then whole can moves in a long circular path instead of rotating at its own axis.
x=1 y=0 z=0 and x=0 y=0 z=1, where z is height.
and
when i will put x=0 y=0 z=0 and x=0 y=0 z=1 can will rotate on its own axis but at the center of can velocity remains 0.
what should i give so i will get axial rotation of can and at center fluid have some velocity.
If i give only wall motion and not cell zone motion, is it correct?
what is difference between moving mesh and moving reference frame?
though in fluent tutorial guide they advised to use moving reference frame for rotation but in animation u will get actual can rotation with moving mesh instead of moving reference frame.
chhanwal is offline   Reply With Quote
Old   March 12, 2011, 07:17
xrs333
xrs333 is on a distinguished road
pls describe your physical problem, then we can give advice and explaination.
xrs333 is offline   Reply With Quote
Old   March 13, 2011, 22:30
Post
Narayansing
milk can rotation where can will rotate along the axis thus inside milk also rotate.
milk is fluid and defined as volume i.e cell zone...can wall rotation has to be defined in wall boundary conditions.
For mesh in motion two options are there moving reference frame and moving mesh..so which option is proper for rotation.
rotation direction is confusing...it should be X axis=1 or 0 so that can should rotate on its axis.
Old   March 19, 2011, 02:23
yagizb
yagizb is on a distinguished road
using moving mesh option, you allow your mesh to rotate really,
but with using moving reference frame, fluent just adds a source to term to the equations.
moving reference frame makes the problem easy,
just look this web page.
http://download.autodesk.com/us/algo..._reference.htm
yagizb is offline   Reply With Quote
moving mesh, moving reference frame, rotation
Problem with patch rotation using pointDisplacement cwang5 OpenFOAM Running, Solving & CFD 3 July 26, 2010 09:54
How to set domain translation and rotation in CFX ricardo.halfeld CFX 7 September 8, 2009 18:22
Rotation Boundary Condition rswbroers OpenFOAM Running, Solving & CFD 17 February 6, 2008 05:30
Axis of rotation for centrifugal compressor Mattia FLUENT 4 October 22, 2007 11:05
Problem Setup: Bi-Axial Rotation Possible? Harmeet CFX 6 February 11, 2005 15:27
