Multiphase Mass transfer UDF issue
Prev Previous Post   Next Post Next
Old   April 21, 2011, 14:51
Default Multiphase Mass transfer UDF issue
John
therandomestname is on a distinguished road
I am simulating a fixed bed wood gasifier using the Euler-Euler multiphase model. I have 2 het rxns and 2 mass transfer equations to simulate the pyrolysis.
I am able to hook my het_rxn_rate udfs into fluent and converge a solution with these running. However, FLUENT will not run my mass transfer UDFs. They compile, I set up the mass transfer in the phase interaction panel and select my UDF names for the rate, but for some reason when I run the calculation I do not see any residual for the species I am mass transfering to (CO and CO2) and when I get my solution the mass fraction of these species is 0. Also, every time I go back to the phase interaction panel, the rate of the mass transfer is still listed as user defined, but the name of my UDFs is not shown in the box. Is this a problem with the UDF (i.e. the number out is equal to 0, though this seems unlikely since it is a relatively simple UDF) or am i just setting up something incorrectly in the interface?
therandomestname is offline   Reply With Quote
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
About phase change heat and mass transfer Michael FLUENT 2 February 13, 2011 01:49
Determining the mass transfer reaction? Lindz Fluent UDF and Scheme Programming 0 September 30, 2009 08:36
Interphase mass transfer in Eulerian-Lagrangian Sameer CFX 0 December 7, 2007 03:49
