gambit and real volume
Old   May 23, 2008, 07:20
Default gambit and real volume
simona
Hi, I'm a problem with a file that I have imported in Gambit. It is a .stl file and Gambit consider it as a NON-REAL VOLUME. But I want to convert it in a REAL volume, because I want to intersect this geometry with a sphere that I create directly in Gambit. My question is: how convert this geometry in a real vomlume? I have tryed, but an error occurred: the volume have to be MAPPED MESHED. But I can't create a mapped mesh for this geometry. Please, help me. Thank you very much. Simo
Old   May 23, 2008, 09:09
Default Re: gambit and real volume
bohis
try to use other import format such as iges or acis
good luck
Old   May 26, 2008, 07:53
Simona
Hi, but my file is a .dbs (or .msh file, or .stl)... I can't open with acis or iegs, I suppose..
Old   May 26, 2008, 08:10
bohis
ok, I have expected that you can use import format you want. Where did you draw your geometry?
Old   April 29, 2011, 14:08
Default Hi
goyalnn is on a distinguished road
I have created a hospital room geometry whcihis divided into three volumes. Is it possible to mesh non-real volumes without converting into real ones?
goyalnn is offline   Reply With Quote
Old   May 2, 2011, 02:22
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Yes you can mesh non-real volumes
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
what is the real mean of "backflow volume fraction zlnbaby FLUENT 3 February 18, 2011 08:56
convert virtual volume to a real one djalil FLUENT 0 January 22, 2009 15:07
virtual or real flow volume for wind tunnel? qm FLUENT 1 January 9, 2009 15:26
Representing real length in Gambit souzan FLUENT 4 May 20, 2008 04:34
Real Volume Substraction taskin FLUENT 3 October 11, 2004 05:55
