is this an erorr |"Thread 5 has 165 contiguous re"
Old   December 17, 2008, 02:03
Default is this an erorr |"Thread 5 has 165 contiguous re"
Conan
when i import Gambit gird into Fluent, there is a message "Warning: Thread 5 has 165 contiguous regions". In my model, there is 1 fluid domain and 165 solid domains. fluid-solid coupled.
Does this affect the computation? or no any effects.
thank you.
Old   December 17, 2008, 16:50
Default Re: is this an erorr |"Thread 5 has 165 contiguous
Justin
Hopefully someone will chime in who has more experience, but I have gotten something similar in the past. It was recommended on the university fluent forums that if the geometry checks passed in Gambit and the grid check passes after importing into fluent this message could safely be ignored.
Old   December 18, 2008, 03:16
Conan
thank you. gird check is ok, no error or warning message. is it safe for computation?
Old   December 18, 2008, 05:20
mange
I agree with justin, usually the grid works if it passes the grid check. Maybe you can make a small test run of your grid before starting your actual computations?
Old   May 22, 2009, 11:43
Default It may cause divergence problem
Steven-GY is on a distinguished road
I have the same problem with my mesh in a conjugate heat transfer application (using Fluent). No problem with the mesh check. However, I could not get a converged solution. While my calculation using a good mesh, there is no problem.
Steven-GY is offline   Reply With Quote
Old   May 31, 2011, 08:34
xufan
FairyHUST is on a distinguished road
Originally Posted by Justin
;155464
thank you vrry much,now i meet the same problem
FairyHUST is offline   Reply With Quote
warning: thread 1 has 4 contiguous regions mindyzeng FLUENT 1 July 15, 2009 07:19
Warning: Thread 1 has 2 contiguous regions. Raj FLUENT 0 December 2, 2008 03:16
Error: domain-thread-integrals: invalid thread per FLUENT 0 March 29, 2008 03:40
Accessing cell thread from a boundary face thread? Vishal FLUENT 2 March 21, 2006 07:29
Warning: Thread 18 has 50 contiguous regions. Laxminarayana FLUENT 0 February 16, 2005 02:09
