June 6, 2011, 10:02 |
export data
EH
I have a Fluent model where I would like to export out the coordinates of all the nodes in my mesh into a text file. Does anyone know if this can be done? If yes, how do I do it? So far, the export options in fluent seems to be giving formats for softwares like ABAQUS, PATRAN, NASTRAN etc. Thanks in advance, EH |
June 6, 2011, 12:21 |
Neil
You could try initialising your grid with the default values then save the .dat file in ascii format then open the file in a text editor. I've used this in the past to extract certain things and I'm pretty sure it should contain x,y,z arrays for the node locations near the top of the file. It can take some time though as even small grids will produce alot of text to sift through.
Neil |
June 6, 2011, 16:34 |
I could successfully export the data as an I-DEAS file and read in a text/wordpad document with data spread according to the X-Y-Z coordinates.
how to export every data w.r.t time to txt file | jaho | CFX | 94 | August 25, 2015 09:45 |
export data at nodes | Meenu | FLUENT | 1 | December 30, 2011 01:24 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
Export data from several .res files | Nessan | CFX | 2 | April 14, 2004 12:56 |
