June 8, 2011, 04:30 |
natural ventilation
henri
hello all,
I want to determine my required opening size for natural ventilation in a closed building. Inside there is a source of heat that I modeled as a rectangle and heat flux BC. In reality that surface is isolated so the temperature should not be more than building temperature but I cant set heat flux and temp. at the same time. My outside temperature is 25C, and I want to be able to keep 50C max in my building. I have tried many things but I dont get any convergence or realistic results(boussinesq, transient...). my inlet at the bottom is pressure inlet at 0barg and my outlet at the top is pressure outlet at also 0barg ( I am also a bit confused if I should put or not the hydrostatic pressure corresponding to rho*g*h at the outlet for taking account the 21m of my building or fluent take that into account....). I tried to have as a start a rough structured mesh with edge size of 0.2 all over my geometry. After calculatin of Ra, and boussinesq condition, i thought i could use laminar and boussinesq in steady to calculate, but since i dont get anything which looks right, I have a doubt on my way to determine those numbers. I would be gratefull, if anyone with experience on this type of problem could help me. Thanks |
Fluent natural ventilation pressure boundary condition | pierresandre | FLUENT | 24 | November 8, 2011 14:32 |
Natural Ventilation | Sean | FLUENT | 1 | April 13, 2008 12:50 |
natural ventilation on buildings | bill | FLUENT | 2 | September 30, 2004 07:43 |
Natural ventilation estimation | neihad | Phoenics | 3 | April 1, 2002 02:36 |
Using Phoenics to simulate natural ventilation | Amber | Phoenics | 2 | December 31, 2000 01:38 |
