June 10, 2011, 07:52 |
Question about velocity vectors
Khalid Baker
Rep Power: 17 |
Hi to all I need to plot velocity vectors as curves instead of vectors using the option display>vectors is this can be done?
June 10, 2011, 13:34 |
Rep Power: 15 |
Why not use streamlines if you want curves?
June 11, 2011, 02:55 |
Khalid Baker
Rep Power: 17 |
I use velocity vectors because I want to see the velocity profiles in every section of the pipe as curves I think streamlines cannot show the velocity profiles?
June 14, 2011, 17:36 |
Rep Power: 15 |
Velocity vectors are tangential to the streamline curves. So streamlines show the direction in which the fluid is moving. If you like to have vectors, you can increase their number (depending on your memory) and decrease their size proportionately to capture the flow profile in the curved sections of the pipe. This is how people make recirculation etc. display.
June 15, 2011, 04:43 |
Khalid Baker
Rep Power: 17 |
OK how I can use streamline option? I cannot find similar option for it? Is it available in display menu?
June 15, 2011, 16:47 |
Rep Power: 15 |
I remember Display->Contours->Velocity->Stream Function. I am unable to verify it now as my simulation is running and it takes almost 15 minutes to stop and restart it again. Sorry about that. Also, streamlines might work only for 2D simulations in Fluent. If yours is 3D, may be path line is a better option (http://jullio.pe.kr/fluent6.1/help/html/ug/node950.htm).
[OpenFOAM] Visualize velocity vectors along a line | Ruehri | ParaView | 1 | July 29, 2010 16:29 |
2 velocity vectors | ashish | CFX | 3 | June 19, 2007 18:32 |
how to display a clear vectors of velocity | clauss | FLUENT | 1 | October 24, 2006 07:30 |
how velocity vectors are moving ,pls answer | ravi | CFX | 0 | October 28, 2005 08:08 |
FIDAP/ FIPOST - velocity vector plot question ???? | Vitaliy Pavlyk | FLUENT | 1 | April 18, 2001 15:04 |
