defining dynamic mesh
Old   July 6, 2011, 08:36
Default defining dynamic mesh
Alex Poyser
atothep is on a distinguished road
when defining a dynamic mesh do i need to mesh the dynamic and the static part seperately and then assemble the two parts in fluent?
atothep is offline   Reply With Quote
Old   July 6, 2011, 10:25
Adrien Lemoine
AdrienL is on a distinguished road
you don't have to mesh it separetly but you have to assign different names to the fluid zones and boundary conditions.
Adrien
Plz add reputation if the answer is correct
A cœur vaillant rien d'impossible
AdrienL is offline   Reply With Quote
Old   July 6, 2011, 12:08
Alex Poyser
So for example a archimedes screw turning in a chamber with a small clearence must be defined with two seperate boundary conditions and then the die at the end of the screw needs to be defined seperately again? I tried using the moving frames of reference like you suggested but apparantly this is not useful when there is a clearence around the archimedes screw.
The clearence allows for clay to move backwards and form a seal within the extruder, which apparantly is another reason why the moving frame of reference won't give me the correct results.
Old   July 6, 2011, 15:24
Adrien Lemoine
can you draw a picture because i don't really get what you mean
Old   July 7, 2011, 04:10
Alex Poyser
Like this only I only have to model the barrel around the archimedes screw and the die. The screw is the rotating zone and the small gap around the screw is a clearence the die is also not rotating.
Thanks
Dynamic mesh, hinged flap Randre FLUENT 37 August 9, 2014 10:40
Dynamic mesh is not getting updated. cardio FLUENT 1 May 20, 2014 08:41
Some questions about mesh updating in dynamic mesh technique lzgwhy Main CFD Forum 0 June 14, 2009 08:01
Dynamic mesh + grid adapt = Crash! (Files included BillH FLUENT 4 July 24, 2007 15:31
Help: Is it possible to use dynamic mesh model and Valery Ponyavin FLUENT 1 September 20, 2003 14:18
