Solving a Laplace equation for a scalar quantity
Like Tree1Likes
  • 1 Post By Amir
Old   July 13, 2011, 04:40
Default Solving a Laplace equation for a scalar quantity
Ali
ali hemmati is on a distinguished road
I am trying to solve \nabla^{2}\varphi=0, i.e. homogeneous Laplace equation, in which \varphi is a scalar quantity and is described in a zone(2D or 3D). We know boundary values of \varphi in borders of the zone. This problem is very analogous to head conduction at steady state, yet \varphi is the electric potential here, not temperature.
I am wondering how to implement this problem in FLUENT. I think I have to mesh the zone and use a udf or something like that.
Thanks for your help.
ali hemmati is offline   Reply With Quote
Old   July 13, 2011, 07:40
Amir's Avatar
Amir
Amir is on a distinguished road
Hi Ali,
you can easily do that by implementing a UDS, user defined scalar; in it's definition, ignore unsteady and convective terms.
Amir
ali hemmati likes this.
Amir is offline   Reply With Quote
Old   October 2, 2014, 11:05
MarkClarence
Clarence91 is on a distinguished road
Hi Amir,
Can you elaborate your statement? How can we justify that unsteady and convective terms can be ignored for solving the laplace equation? (i need to find the change in electric field in my geometry)
I think you know how my geometry looks like :P , I have to find the electric field in the rotor domain.
If possible can you share the UDF with me?
Thank you.
-Mark
Clarence91 is offline   Reply With Quote
Old   October 2, 2014, 13:34
Amir's Avatar
Amir
Originally Posted by Clarence91 View Post
Hi Amir,
Thank you.
-Mark
Dear Mark,
"UDS" is "User-Defined Scalar" equation and is available in FLUENT, something like energy equation and totally different from "UDF"! In the process of enabling a UDS, you can manage the unsteady and convective terms. For more info, please refer to the manual.
Bests,
Amir
Old   February 11, 2015, 19:56
Tharanga Jayathungage Don
Tharanga is on a distinguished road
Send a message via Skype™ to Tharanga
Can we solve defined scalar in x, y, z direction separately (for 3D geometry) or how can we see the scalar values in x y z directions using post processing?
Regards
Tharanga
Tharanga is offline   Reply With Quote
Old   February 12, 2015, 04:02
Amir's Avatar
Amir
Originally Posted by Tharanga View Post
Regards
Tharanga
For sure you cannot solve it separately, but if you want to see the scalar values in a specified direction, you can simply draw a line and plot the scalar values over it...
Bests,
Amir
Old   February 12, 2015, 05:08
Hey, Thank you for the reply. I have solved the laplace eq (3D) and I need to get surface integration over x y z direction (separately) . Is there any method for that? cheers
Old   February 12, 2015, 05:12
If I elaborate more, I cant choose from the drop down menu x-scalar values etc. Therefore, I'm struggling to find x y z values over a surface. Thank you.
Old   February 12, 2015, 05:24
pakk will become famous soon enough
With a user defined scalar, you calculate a scalar, not a vector.
A scalar does not have a x-component... So your question does not make any sense.
If you solved an electrostatic problem, your scalar is probably the electric potential. Which component do you want? The x-component of the electric field? You should know the relation between those two.
pakk is offline   Reply With Quote
Old   February 12, 2015, 05:36
It is a homogenized flow problem. Ultimately, I need to solve laplace eqn (vector) with BC's . Yes, you are right but there is no other way (I think) than UDS method in fluent to solve Laplace. Please suggest me an alternative method. Thank you
Old   February 12, 2015, 06:00
You don't make clear why you need another way. What is wrong with the UDS method?
And are you sure you want a vector laplace equation??? That is very unusual. I don't know why a "homogenized flow problem" would lead to a vector variant of the laplace equation.
Old   February 16, 2015, 20:42
Hi, Thank you very much for your kind replies. I solved it as three different problems in fluent. I got the results.
Regards,
Tharanga
electric potential, heat conduction, laplace equation
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
