August 2, 2011, 20:51 |
DPM Particle types, Spray Dryer
Mohsin Mukhtar
Hello
I am simulating a spray dryer. The solution entering a spray dryer is liquid solution of coal and organic liquid. The aforemementioned solution is injected through the nozzel into the dryer for drying through air. DPM model is being used. I wanted to ask that which "particle types" would i be using to represent the solution enetering the dryer and the reason of using that particular "particle type". The particle types available in FLUENT DPM model are: 1. INERT 2. DROPLET 3. COMBUSTING 4. MULTICOMPONENT I will be grateful for somebody's insight into this question. Thanks Mohsin |
August 2, 2011, 21:26 |
Mohsin Mukhtar
Well, I think "Droplet" particle type would be used because it gives an option of "evaporating specie" which would be the organic liquid in this case, as the coal will be dropped down as a solid particle.
Or As the liquid solution being dryed consists of two components namely, solid Coal and orgainc liquid, Should i use multicomponenet in this case? Last edited by Mohsin; August 2, 2011 at 22:11. |
dpm, spray dryer |
DPM particle time step | amos | FLUENT | 1 | January 4, 2020 08:46 |
How to put melting point data of inert particle in DPM model of Fluent | subhankar_bhandari | Fluent UDF and Scheme Programming | 1 | February 5, 2018 07:08 |
DPM particle tracking in stirred tank | parisa- | FLUENT | 1 | August 7, 2012 12:03 |
DPM particle tracking | parisa- | Main CFD Forum | 2 | June 15, 2011 05:12 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
