I need to fix total volume fraction
Old   January 17, 2007, 07:32
Default I need to fix total volume fraction
Yasser
hello i am using eulerian two phase model to simulate the flow in mixing tank. after post processing, i find the solid volume fraction become lower than its patched value ....
I read that another one used UDF to fix the total volume fraction to a certain value and he gave this link in the references
http//www.fluentusers.com/udf_archieve/udf_examples/UDF52.htm
but i don't have access to this site can anyone help me? thank you
Old   January 17, 2007, 12:12
Default Re: I need to fix total volume fraction
Suijth
what is your simulation?
If you just want to keep the initial values of the vol fraction, you can turn off the volume fraction equation from solving it, in the solution controls panel..
-Sujith S Nair
Old   January 17, 2007, 12:24
Yasser
i am modelling two phase flow (solid-liquid) in mixing tank and thx for your suggestion
i don't want to keep the initial values ... i am studying solids concentration. just i need the total volume fraction in the tank be the same as initially patched.
thx for reply
Old   January 17, 2007, 16:19
Sujith
After patching your initial value of the patched variable will be over written. if u want to keep this for rest of simulation , you can switch off vof eqn.
Old   January 17, 2007, 16:47
Yasser
Thanks very much
Old   January 18, 2007, 01:25
Yasser
hello now i turned the equation off, but the volume fraction didn't change from cell to another
i need the volume fraction of solids to change from cell to another but i need the average volume concentration overall the tank to remain constant (which is not happened when turning the vof eq. on).
thx
Yasser
Old   August 1, 2011, 15:14
Default Urgent!!
Olusogo fire
phire is on a distinguished road
pls yasser. I am working on the scour under pipeline. I am having the same problem you had. Where you able to find solution to it. I will really appreciate your response cos I have to submit my Thesis by august 9. thank you very much
phire is offline   Reply With Quote
Old   August 1, 2011, 15:15
Olusogo fire
Originally Posted by Yasser
;138273
thx
Yasser
pls yasser. I am working on the scour under pipeline. I am having the same problem you had about the volume fraction reducing. Were you able to find solution to it. I will really appreciate your response cos I have to submit my Thesis by august 9 I can get result due to the wrong volume fraction result. thank you very much
Old   August 3, 2011, 08:10
zino
zino is on a distinguished road
I think you need mass conservation. there are options in multiphase. I have used eulerian approach. that approach provide mass conservation option
zino is offline   Reply With Quote
Old   August 3, 2011, 13:37
Olusogo fire
@zino Pls how do I set mass conservation because I am using eulerian granular phase model in which sand is taken as the granular phase while water is the continuum
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
Volume fraction of dispersed phase to determine DPM, VOF, Mixture model Mohsin FLUENT 5 March 5, 2018 07:47
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
multiphase... solid volume fraction anomaly Tim CFX 4 February 14, 2012 04:01
Volume Fraction cheong FLUENT 1 November 28, 2001 04:06
