Question about Axisymmetric solver.
Old   August 5, 2011, 20:26
Default Question about Axisymmetric solver.
SleeperService is on a distinguished road
Hi all
I'm doing a study with a 2D axisymmetric setting. In this study, there is a particular zone that acts as an energy source. This semicircular zone is intended to be rotated about the axis to model a spherical region of plasma.
Now, I have defined an energy source term within that zone, and I know the total energy deposited per second within the sphere (7W), and I know that this small region has a radius of 0.25 mm.
Now, calculating the volumetric heating as simply Power/Volume results in a figure of the order 10^10 W/m3
Now, my question is this: I'm unsure if I should be calculating the volumetric heating based upon the volume, as I've done above, or if I should simply calculate it over the semicircular area, which is then integrated around the axis BY FLUENT automatically - I have no idea what Fluent would actually do, so I'm hoping someone who's experienced in axisymmetric solution can advise me on this.
Thanks in advance.
SleeperService is offline   Reply With Quote
Old   August 8, 2011, 10:17
jsm
JSM
jsm is on a distinguished road
You need to give the full source as like 3D analysis. No need to convert the source to axi symmetric analysis.
With regards,
JSM
jsm is offline   Reply With Quote
Old   August 8, 2011, 17:13
OK, awesome. That means I've done it right then. Thanks.
smoothSolver diverges - solution in using PBiCG solver? makaveli_lcf OpenFOAM Running, Solving & CFD 3 September 11, 2013 12:44
question about the volume integral in axisymmetric problem Renold FLUENT 0 December 7, 2009 11:28
Solver and geometry choose for drag coefficient calculation around circular cylinder at large Re lin OpenFOAM Running, Solving & CFD 3 April 16, 2009 10:50
Fluent solver question ? prasat FLUENT 1 August 25, 2003 09:27
Error message Pandu Sattvika CFX 0 March 1, 2002 15:28
