Reason for Lift Coefficient Error
Old   August 15, 2011, 05:12
Default Reason for Lift Coefficient Error
Josh
jsuf is on a distinguished road
Hi everyone,
I've been running some simulations for an airfoil at various angles of attack (up to 6 degrees) with properties;
Re = 1000, laminar model, second order density based solver, free stream velocity = 1 (varied viscosity to obtain Re).
I'm getting lift and drag coefficient errors of order 5-10%, which for what I'm doing is ample. However, my drag coefficient is much more accurate than my lift. I'm curious as to what mechanisms would cause this, as I would expect drag to have a greater error (due to difficulties in resolving boundary layer).
Is there anything in particular in a mesh or Fluent setup which would affect lift in this way?
On a side note, I've also noticed that my 3D tests (allowing wing tip effects) are much more accurate than my 2D. I didn't expect this either. My 3D models are simple swept face versions of my 2D ones.
Thoughts?
Regards,
Josh
jsuf is offline   Reply With Quote
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
