Heat Exchanger Model
Old   November 16, 2011, 08:09
Default Heat Exchanger Model
andrey rushin
andrey_rushin is on a distinguished road
I try to use the Heat Exchanger Model of FLUENT and detect, that using of more then one HX produces wrong temperature difference between in- and outflow on one of used HX. Determination of one HX only in system deliveres correct temperature values...
Does somebody know something about this problem?
Thanks!
andrey_rushin is offline   Reply With Quote
Old   November 17, 2011, 05:38
andrey rushin
you are right, I give too much information
Easiest way to establish communication is to discribe one example. Please imagine to have in your system two heat exchangers - radiator and condenser. For each HX you define in FLUENT a table that consits of heat rejections with coolant flow and air massflow. So far ok.
Regarding to actual flow field conditions one appropriate combination of heat rejection, coolant massflow and air massflow will be extracted from given table. As a result I expect one HX inlet temperature, which corresponds to formula:
Tin = Tamb + Q/(e*Cp*Mp)
where:
Tin - coolant inlet temperature (predicted)
Tamb - environment temperature
Q - actual heat rejection
e - effectiveness
Cp - heat capacity of air
Mp - massflow air
If I use in system only one HX, the solved Tin is exactly one like solved using the formula. Two HX in same system deliver wrong Tin...
I am sorry for broken english
Heat Exchanger Model sak2129 FLUENT 3 September 26, 2017 01:29
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Heat Exchanger Model - urgent JSM FLUENT 6 September 22, 2007 04:25
BIG TROUBLE with heat exchanger and porous media!! Andrea FLUENT 0 February 20, 2005 07:49
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
