June 2, 2023, 10:32 |
autosave file format
Abbas Dorri
Rep Power: 3 |
Hi everybody,
I used autosave for saving the fluent results every 40 times. When I wanted to load the results files in Tecplot, their format was case.h5 and dat.h5 instead of .case and .dat. I could not load the data since I encountered error in Tecplot. How can I solve my problem? Sincerely, |
June 8, 2023, 07:57 |
Moritz Kuhn
Rep Power: 17 |
Write a journal file, whichs open every case.h5 and dat.h5 file and save it again as a pur cas and dat file.
For future simulation look here. |
June 8, 2023, 08:05 |
Abbas Dorri
Rep Power: 3 |
Thank you for your help.
I changed the "FFF" in preferences of file into "legacy". The problem completely was solved |
June 8, 2023, 14:52 |
Lucky
Rep Power: 66 |
MK wrote their response on the assumption that you already had a bunch of cases accidentally saved in the newer h5 format and cannot load them into tecplot. Opening and saving them in the older format would therefore allow you to open them in tecplot.
Clearly, saving your simulation .cas and .dat in the first place would avoid this problem. But that was obvious obviously for obvious reasons Interestingly your post described the former problem and didn't ask how to save in the older format. |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
