return in udf
Old   September 20, 2011, 15:00
Default return in udf
raymond
wlt_1985 is on a distinguished road
What is the main function of 'return' in udf? Since I had gone through the guide and I found that certain udf with 'return' while some did not. What the different of udf with 'return' and udf with no 'return'?
wlt_1985 is offline   Reply With Quote
Old   September 20, 2011, 15:07
Amir's Avatar
Amir
Amir is on a distinguished road
Dear Raymond,
if your macro is void-type, it wouldn't return any value and it just does some settings, but if it isn't void-type, it return a value and needs return command.
Bests,
Amir
Amir is offline   Reply With Quote
Old   September 21, 2011, 01:26
raymond
Originally Posted by Amir View Post
Dear Raymond,
Bests,
Thanks Amir. For example, I am having changes in species during the modelling, then I am either using macro DEFINE_SOURCE or DEFINE_VR_RATE. DEFINE_SOURCE does have 'return' while DEFINE_VR_RATE does not have. Does it mean that DEFINE_VR_RATE just doing some setting which has been pre-defined in Fluent while DEFINE_SOURCE calling for calculation and return the value to the model? Please help.
Old   September 21, 2011, 02:16
Kristian Etienne Einarsrud
KristianEtienne is on a distinguished road
Your reasoning is correct; In DEFINE_SOURCE, you return the value of the source directly (through the "return" command), while in DEFINE_VR_RATE you update the specific reaction rate pointer (*rr_t) which is predefined by FLUENT.
Cheers!
KristianEtienne is offline   Reply With Quote
Old   September 21, 2011, 02:26
Amir's Avatar
Amir
Exactly; in DEFINE_SOURCE, there isn't any argument which refers to source value, so we define a real variable, e.g. source, and use return function at the end;
return source
But in DEFINE_VR_RATE, there are two argument which are pre-defined for FLUENT and you can store desired data in them. It's defined for this macro which variable should be returned, so you wouldn't need return command.
Bests,
Amir
Old   September 21, 2011, 04:35
raymond
return source
Bests,
Thanks Amir.
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
Parallelizing a UDF tstorm Fluent UDF and Scheme Programming 3 August 20, 2009 12:31
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
I need UDF help. S.Whitney FLUENT 0 October 15, 2007 11:29
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
