Lubomir
Rep Power: 0 ![]() |
Hi Guys.
I have an unsolvable problem. I am beginner in CFD. I would like to model Karman vortex trail - school experiment. Real experiment: Pipe is placed in center of river. Behind the pipe are generated Karman vortexes. I know the velicity inlet. That´s all. The problem: I have mesh(Gambit) of this problem, 2D solution. What are the boundary types for outlet and for two side edges? I tried calculation but after 12000 iterations were no convergence - still oscilated. I am not sure if I set all the parameters right. Can You help me? Please give me advise what,where and how I must set ![]() Thanks. |
anonym
Rep Power: 17 ![]() |
Boundary conditions for outlet: outflow or pressure-outlet (with the proper pressure value)
The walls should be simply wall ![]() Since the simulation of Kármán vortexes is transient, you should go for time-dependent simulation. Did you do that? From the oscillating residuals I guess you didn't. |
