October 28, 2011, 07:45 |
Porous Jump - metal grid
Flavio
Rep Power: 15 |
Hi everybody,
I'm working on a burner (1mm thickness): it's a metal woven grid and I decided to model it with porous jump in Fluent From an experiment I got these coefficients (quadratic fitting as suggested in the guide): alfa = 1.4e-10 C2= 450000 I don't know if these are realistic values... what do you think? Last edited by Bionico; November 1, 2011 at 12:52. |
November 1, 2011, 12:58 |
Flavio
Rep Power: 15 |
Moreover I did a simulation of the experiment with a pipe and the burner inside: to reach the pressure drop measured I had to fix C2 coefficients to 4500: 2 order lower than the computed one from the real experiment!!!!
The permeability should be realistic because the grid is very dense, but I don't know if C2 should be high or low... which data I have to take into account? experimental or simulation ones?? Please help me! Last edited by Bionico; November 2, 2011 at 03:08. |
November 7, 2011, 02:01 |
Rep Power: 17 |
According to my experience, the experimental coeef do not always give you the pr drop you need. You need to modify the coeff and it's the C2 that generally varies a lot. As long as you get the pr drop you require in your CFD model, go ahead.
[ICEM] How can I define different zones in ICEM? | llrr | ANSYS Meshing & Geometry | 14 | February 12, 2017 13:44 |
[Commercial meshers] Porous Jump creation problem | mulfal | OpenFOAM Meshing & Mesh Conversion | 4 | December 9, 2013 11:59 |
Porous jump in urban environment | samygero | FLUENT | 0 | February 14, 2011 18:26 |
Testing the integrity of POROUS media and por jump | Azman | FLUENT | 0 | July 31, 2006 11:11 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
