Droplet Impingement Simulation Refinement
Like Tree2Likes
  • 1 Post By wbka
  • 1 Post By subha_meter
Old   November 20, 2011, 22:35
Post Droplet Impingement Simulation Refinement
Ar
skel_1 is on a distinguished road
I am trying to model the impingement of a droplet on a solid surface. So far I have run an axisymmetric case with the VOF model (implicit body force, unsteady, implicit) and used the Static Contact Angle approach. I have used an uniform quad mesh which is very refined. But however, after the first impact the droplet seems to split up in two and then rejoin and then further illustrate the oscillations with the pinning and depinning phenomena. However, I am not satisfied with it.
I would like your opinion about the following:
1. Is using a Dynamic mesh necessary to reduce computation time if I want to use a coarse mesh throughout and just refine the near interface region and the droplet moves.
1 a. Has anyone done this?
2. I am new at using UDF's, but would like to learn how to include the different models for dynamic contact angles(DCA) to better simulate experimental conditions? Would the UDF give me options in specifying the contact angle in the wall adhesion tab in boundary conditions.
3. In case of using a UDF I would like to be able to read the velocity of the contact line and thus compute the dynamic contact angle from there which would be used in Fluent's CSF formulation to compute the droplet spreading. Can anyone help with this?
Thanks
Skel.
skel_1 is offline   Reply With Quote
Old   February 20, 2012, 01:06
Default Dynamic contact angle
subha_meter's Avatar
Subhasish Mitra
subha_meter is on a distinguished road
The droplet may split into two/multiple fragments depending on the Weber no at the time of impact. If the impact velocity is very high, there's possibility drop will split. However use of static contact angle is a limitation to model such kind of problem where the contact line keeps on moving and no slip boundary condition at the wall is not the appropriate BC. To overcome such problem, a time dependent contact angle (dynamic contact angle) profile can be applied through "define profile" macro.
Regards,
SM
SM
subha_meter is offline   Reply With Quote
Old   April 21, 2013, 18:01
Default BC
wbka is on a distinguished road
Hello ,
Hello , could you tell me what boundary conditions you used , please ?
thanks in advance
kmou likes this.
wbka is offline   Reply With Quote
Old   June 24, 2013, 23:03
Default Droplet impingement
Subhasish Mitra
Originally Posted by wbka View Post
Hello ,
thanks in advance
If this thread is still alive, a dynamic contact angle boundary condition is indeed required on the solid wall which could either an experimentally measured profile or an analytical expression as a function of three phase contact line velocity. A UDF will be needed to capture the velocity near the spreading edge (gas-liquid interface) of the droplet and with this velocity the dynamic contact angle needs to be calculated.
kmou likes this.
SM
droplet, dynamic contact angle, dynamic mesh, udf, vof
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
droplet simulation over flat plate openfoam1 OpenFOAM 11 December 16, 2010 08:45
Replacing mesh while running a simulation akultane CFX 1 November 15, 2009 13:46
droplet simulation andre_001 OpenFOAM 0 August 17, 2009 04:07
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 10:06
