Complex Geometry with ICEM/FLUENT
Old   November 22, 2011, 05:23
Default Complex Geometry with ICEM/FLUENT
Nicolas Book
N.Book is on a distinguished road
Hi.
I have a rather basic question concerning the modeling of complex structures in ICEM before exporting the mesh to FLUENT.
The structure which I want to model is a 2D channel with lots of corners and sections on different levels (consider a multiple bended pipe-system expanding in both x and y direction). I am using ICEM to model it in 2D.
My question is how to mesh it in a appropriate way. Is it possible to have several (fluid-) surfaces in a single geometry? ICEM is adding an additional curve between those surfaces (which however is still of the part "fluid") and I get the problem that FLUENT will give me an access-violation as Zone1 is invalid.
However, a single surface seems to be difficult to model as ICEM is distorting surfaces that are defined by more than 4 lines which additionally often intersect the surface to be built. It seems to be adding new lines ending somewhere within the surface. That's why I would prefer to have several surfaces adjacent to each other.
Is that possible or is there a more elegant way?
Thanks for any help.
Nic
N.Book is offline   Reply With Quote
fluent 13.0, fluent 2d, icem 2d, mesh export
Gambit - Mesh Problem for a complex 3D geometry Nelson FLUENT 3 May 28, 2012 06:57
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 11, 2012 23:18
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
How to construct complex 3D geometry using GAMBIT? Feng FLUENT 5 October 11, 2005 04:13
