backward facing step
Old   October 24, 2005, 03:05
Default backward facing step
erni
hi all; I am planning to make a simple air flow simulation with a backward facing step geometry (included friction) and searching a done experimental or numerical work (with Fluent) where I can compare my results . I would like to know if any of you already worked with such a geometry? Thanks in advance
Old   October 24, 2005, 09:17
Default Re: backward facing step
Riaan
Hi Erni,
I just completed my thesis on the Kline-fogleman airfoil (Diamond wing with backward facing step on the windward surface) - so I have some experience with this type of geometry.
I can also advise to look on the www.fluentusers.com - I remeber seeing a tutorial on there for a BFS case.
Cheers, Riaan
Old   November 23, 2011, 12:57
Unhappy kline fogleman 2 from naca 23015
Shibin Mohamed
smab is on a distinguished road
hi,
i am currently doing my project on kline fogleman type 2 (with top step) made from a standard naca 23015. i would like to know the fluent settings for the particular profile.
my velocity is about 36 m/s.
pls its very very urgent....
smab is offline   Reply With Quote
Old   November 23, 2011, 13:49
Shibin Mohamed
erni, could u pls provide me with ur case and data files for the Backward Step
airfoil..
my email is smab@in.com
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Backward facing step. Fluids Main CFD Forum 7 December 4, 2012 11:28
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
