Problem in Ansys 13 Licence
Old   December 17, 2011, 23:08
Default Problem in Ansys 13 Licence
shoeb khan
shk12345 is on a distinguished road
Hi
Dear friends i am using ANSYS 13, I have problem in running the software due to license problem.I have generated the license file with the help of magnitude and inbuilt in the license wizard.Still i am not been able to make the software work.
Thanks in advance
Hope you can help me to sort this thing out.
SHK
shk12345 is offline   Reply With Quote
Old   December 19, 2011, 05:47
Philipov's Avatar
Svetlin Filipov
Philipov is on a distinguished road
You do not have lmgrd working.... Check task manager and find out if such process exists. If no - reinstall license manager. If yes - set up license server....
May be it is useful to contact ANSYS support
Philipov is offline   Reply With Quote
Old   December 19, 2011, 13:13
vikas
vikas171092 is on a distinguished road
1) Install Ansys Products
2) Run ANSLIC_ADMIN Utility in under Start/Programs/Ansys/Ansys Client Licensing
3) Click on the Display the License Server Machine Hostid
4) Copy Hostname and Flexid
5) Edit ansys.dat from Licence Generator folder
6) Replace HOSTNAME and FLEXID with the ones copied at step 5
7) Save and close ansys.dat
8) Edit ansyslmd.ini
vikas171092 is offline   Reply With Quote
Old   December 24, 2011, 13:00
Default hi
shoeb khan
Can you send me the link to those files that you have discussed.
Upload them somewhere and kindly send me the link
or mail me at
shoebkhan4u@gmail.com
thanks in advance
shk
Old   January 5, 2012, 05:52
Cool
amir okhovat
amirokhovat is on a distinguished road
Send a message via Skype™ to amirokhovat
Hi dear
you license you're product with you're network adapter.
You must create a virtual network adapter (Microsoft Loop back) and never connect to internet when you work with ansys. when you connect to internet you must restart you're computer.
good luck
amirokhovat is offline   Reply With Quote
Old   January 27, 2013, 07:28
Default ansys 13-licence manager problem
Alime Cengiz
cngz is on a distinguished road
I have a similar problem with ANSYS 13.0 licence manager! . In the moment of licence manager installation, the program doesn't accept the file that I made from "AP13_calc" file! It gives this error: "Invalid licence file: FLEXIm ID in the file does not match the system FLEXIm ID!". I made correctly the installation process, but I couldn't figure out what else I could Could you please help about this, I need that program urgently!! Thanks in advance,
Alime
cngz is offline   Reply With Quote
Old   January 27, 2013, 08:13
amir okhovat
Hi every body
You must create a virtual network card (Microsoft ....) and disable all network devices except Microsoft virtual network. then run AP13_calc.
If you want to use Fluent send an email to me. I send you a license that you can use fluent only.
I prefer you that use Ansys 14. It's easily to install license manager. When you use Ansys 13 and you are connected to internet your CPU temperature is going high about 100c
amir okhovat
Hi every body
Old   January 27, 2013, 09:10
Alime Cengiz
Hi Amirokhovat,
I've created Microsoft loopback but after that I didn't disable all network devices except Microsoft virtual network! I noticed after you, and tried as you said and it works Thank you so much, saved my day
Last question, when I started the ANSYS workbench there are just "component system and design exploration" active. Is it ok? or there should be more?
Old   January 27, 2013, 23:36
SSL
msaeedsadeghi is on a distinguished road
Stop and start license manager. It may be solved.
msaeedsadeghi is offline   Reply With Quote
Old   January 28, 2013, 13:51
Default open evaporating_drops.ccl!
  #11
Alime Cengiz
Thansks for the suggestion. I did it it works. I am trying to do spray dryer tutorial now, but I can not open evaporating_drops.ccl file, because there are lots of ccl file but no open evaporating_drops.ccl file! How can I get it?
Old   February 26, 2013, 07:42
FSG
Flougiman is on a distinguished road
Originally Posted by cngz View Post
Hi Amirokhovat,
hi cngz,
you should change the region and language of your computer to English (united kingdom).
Now your the list in workbench should be larger.
Regards,
an Aerospace Eng.
Flougiman is offline   Reply With Quote
ANSYS Workbench mesh crashes (ANSYSWBU.exe problem) kondan ANSYS 76 February 22, 2024 02:27
ansys problem ENGRTAHIR Main CFD Forum 0 May 11, 2010 16:29
Region Problem with ansys 12 icem mesh for cfx compizer CFX 0 May 5, 2010 03:02
Problem importing GAMBIT mesh to Ansys geometry David G. CFX 0 June 19, 2005 06:01
problem in import ANSYS mesh sheryl CFX 2 April 30, 2005 21:30
