November 29, 2011, 12:47 |
Restitution coefficient wall
naor
Rep Power: 15 |
hello how i specify Restitution coefficient wall ??
thanks |
November 29, 2011, 23:42 |
Rep Power: 14 |
hi. if you working on multiphase flow using Eulerian model you proceed like this:
define -> phases, select secondary phase, set and set Granular Temperature Model to Partial Differential Equation now you can set coefficient of restitution under Boundary Conditions, wall (for second phase) under multiphase. (source:http://www.cfd-online.com/Forums/flu...ase-model.html) |
November 30, 2011, 14:18 |
naor
Rep Power: 15 |
thank u!!!!
but now how can i define the granular temp? |
December 1, 2011, 19:36 |
Rep Power: 14 |
hi. do you mean the value of granular temperature?
you can take the default value 0.0001 . |
December 2, 2011, 02:07 |
naor
Rep Power: 15 |
yea, but i have a value and i dont see were to put it...
December 2, 2011, 04:29 |
Rep Power: 14 |
hi.
like this : boundary condition -->inlet-->secondary phase--> momentum you find granular temperature=0.0001 boundary condition -->outlet-->secondary phase-->multiphase you find back flow granular temperature=0.0001 i hope this will help you. |
December 2, 2011, 08:11 |
naor
Rep Power: 15 |
i will try and let u know
thank u for the help and quick answers. |
December 18, 2011, 11:54 |
naor
Rep Power: 15 |
ok i tried it, but it strange i still cant se the difference.
i use an Eulerian model, and when i try to increased the volume fraction (B.C->velocity inlet-> volume fraction) to 0.02, and make the initialized i get the next massage (before the running of the calc): "turbulent viscosity limited to viscosity ratio of 1.00 e+5 in 27915 cells" what it mean? do E model have a limit of volume fraction? |
Patches for OpenFOAM 1.7 on MacOS X | gschaider | OpenFOAM Installation | 101 | September 21, 2011 05:37 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
help--- coefficient of restitution | Tim | CFX | 0 | June 22, 2006 00:34 |
particle tracking | mike | CFX | 3 | April 17, 2006 00:05 |
