January 16, 2012, 13:54 |
Interpolation of the results....HOW???
mohammad
Rep Power: 16 |
Hello everybody,
I have a question about interpolation of the results for same models [with different node arrangements and same Geometries.] As i know this is possible in CFX that we initially solve the model with fewer nodes for a while, then use the results as the initial values and run the same geometry with just higher number of nodes. Is this method possible in FLUENT? and how should i import the initial value file. regards, |
January 17, 2012, 09:19 |
shoeb khan
Rep Power: 14 |
hi amir
tell me something more about the interpolate . shk |
January 23, 2012, 06:47 |
mohammad
Rep Power: 16 |
Hi everybody, hi Amir
I did it as the help manual...but the results are awkward...about 500 times bigger than what i expected. 1) I made a model with small number of nodes----> I solved it---> results look to be in-range.---> i saved an "Interpolate" file 2) I generated the same model with higher number of nodes---->I imported the "interpolate" file from step 1---> i ran the model https://www.sharcnet.ca/Software/Flu...ug/node137.htm as i told , the results are really bad.... what could be the cause? Regards, Last edited by mohammad; January 23, 2012 at 07:04. |
January 23, 2012, 08:12 |
Did you save all of the fields in interpolate file? velocity, pressure, .... Did you save the interpolate file of the converged solution? when you import the interpolate file in a finer grid, check all the fields and BCs before iteration. At last, maybe your solution hasn't converged yet. Bests,
Amir |
January 23, 2012, 13:28 |
mohammad
Rep Power: 16 |
Hi dear Amir,
All are ok...but i think the last one is the cause. Anyway...thank you for your help man. Regards |
urgent help needed (rhie-chow interpolation problem) | Ardalan | Main CFD Forum | 2 | March 18, 2011 15:22 |
Surface interpolation schemes and parallelization | jutta | OpenFOAM Running, Solving & CFD | 0 | February 25, 2010 14:32 |
momentum interpolation for collocated grid | Hadian | Main CFD Forum | 4 | December 25, 2009 07:25 |
interpolation or mapping a result into another model | amazdeh | CFX | 5 | April 1, 2009 09:45 |
Wrong result with bilinear interpolation | zonexo | Main CFD Forum | 1 | June 12, 2007 15:55 |
