Shock tube at high mach numbers-ANSYS Fluent
Old   February 9, 2012, 19:58
Default Shock tube at high mach numbers-ANSYS Fluent
Aditya
dsn2491 is on a distinguished road
HI,
I am simulating the driven section and th shocked gas region of a shock tube in fluent. there seems to be a small jump in the initiallly set values and then the variation reduces and the solution proceeds as it is supposed to proceed.
I am using an explicit AUSM scheme with first order upwind for flow option in spatial discretization. the courant number is set to 1. the mach number of solution is 1.7
Can anyone tell me why this is happening? the effect increases drastically and the calculation just goes off track whenthe mach number is high(M=2.1,2.8)
What are the changes that need to be done...is the courant number or any other thing that i need to look into
response will be highly appreciated.
Attached are the lineouts for the M=1.7 case
dsn2491 is offline   Reply With Quote
Old   March 7, 2012, 12:34
xpto56 is on a distinguished road
Hi!!!
Unfortunately I'll be of no help to your problem.
I'm also trying to work my way around the shock tube problem in Fluent. So, I was hopping if you could lead my way into setting the driver and driven conditions properly.
Thanks!!!
xpto56 is offline   Reply With Quote
Old   March 8, 2012, 18:28
Aditya
I have a UDF set-up which initialises the driven gas of the shock tube. I only have the driven gas in my simulation so its basically unshocked gas and a small portion of the shocked gas (State 2).
I dont have the driver gas section of the shock tube.
Old   May 21, 2012, 20:07
navid
ndabir is on a distinguished road
Hi, could you please let me know how did you set up the B.C for your simulation?
ndabir is offline   Reply With Quote
Shock Tube problem mouna lamnaouer FLUENT 1 September 22, 2011 12:47
FSI, Fluent Ansys coupling Greg Carnie FLUENT 5 January 7, 2010 19:15
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
shock tube validation AB Main CFD Forum 3 December 10, 2004 07:31
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
