Problem in laminar natural convection in cavity
Old   June 26, 2014, 06:06
Default Problem in laminar natural convection in cavity
realfear is on a distinguished road
hi every one
i have modeled a 2d cavity in fluent and openfoam for natural convection heat transfer
they gave me the same results but not the same with the experimental results.
so i'm asking for your advices
the upper edge in cavity is adiabatic and left and right wall are in constant temp (Tc) and a part of lower wall is in constant temp(Th) and some part of it are adiabatic
i have attached the steps i used in modeling the problem in fluent and the results as well
i really need your helps because i;m about to fail my coarse!!!
thank you in advance
Nuextent.xlsx
realfear is offline   Reply With Quote
Old   June 26, 2014, 06:08
the other steps
Old   June 26, 2014, 08:44
Mustafa
Mohawk is on a distinguished road
From density choose boussniq
Mohawk is offline   Reply With Quote
Old   June 26, 2014, 09:09
i did but it converged with 3 iterations!!!!!!!!!!!!!!!!!!!!!
Old   June 27, 2014, 05:10
Default asking for help
anyone ????
please
i need help!!
Old   June 27, 2014, 09:55
kad
kad will become famous soon enoughkad will become famous soon enough
Make sure that Nusselt number is calculated the same way in simulation and experiment. Nusselt number in fluent is calculated as,
Nu = \frac{h_{eff} \cdot L_{ref}}{k}
with
h_{eff} = \frac{q}{T_{wall}-T_{ref}} .
q is the local heat flux, k is the local heat conductivity. The reference values are defined in the corresponding panel "reference values" in fluent (Length and Temperature).
kad is offline   Reply With Quote
Old   June 27, 2014, 10:47
with
tanx for responding
i used Forward finite difference scheme for calculating Nu
Nu was defined as d(teta)/dY
teta is the dimensionless temperature
Y is the dimensionless lenght
Natural convection convergence problem Bruno Machado FLUENT 10 January 31, 2018 04:18
Problem with natural convection claudia.h FLUENT 2 July 3, 2012 03:10
transient simulation: natural convection problem? Basics CFX 3 September 25, 2002 09:42
ON TURBULET MODEL FOR A NATURAL CONVECTION PROBLEM varghese FLUENT 6 February 6, 2002 05:23
Natural Convection Problem Sridhar FLUENT 2 September 13, 2001 15:16
