Convergence problem with target mass flow rate |
March 13, 2012, 05:12 |
I'm running an unsetady simulation of an uncompressible flow in a pipe with three outlets. I've imposed a velocity profile at the inlet using a UDF (peak Re around 4000). I also have imposed the target mass flow rates at two of the outlets using a UDF and pressure outlet boundary condition, the mass flow rate is defined by an equation where the current time is a variable. The third outlet has a pressure outlet BC but no target mass flow rate specified. I haven't changed the gauge pressure as my flow is not supersonic. However the simulation doesn't converge at second order and fluent ignores my instruction about the mass flow rate. The mass flow rate at the outlet for each time step is not the one I'm imposing with the function. Can anyone help me with this? Thanks a lot |
March 20, 2012, 14:05 |
I also had problems with target mass flow rate ....... I just deactivated the target mass flow rate and adapted the pressure so that I get the mass flow I want, but my simulation is steady state, so that’s maybe not working for you.
Anyone else?? |
May 29, 2012, 21:11 |
Same problem
Pete
Hi, I am facing the same problem. Were you able to solve your problem ADL? Kindly let me know, if you have. Thank you
how to calculate mass flow rate /simpleFoam | greel | OpenFOAM Post-Processing | 15 | November 16, 2012 00:16 |
Discrete Phase & Mass Flow Rate | MagnusZeus | FLUENT | 0 | December 2, 2011 17:57 |
Mass flow rate | sepidecent | CFX | 0 | August 9, 2011 00:15 |
I have a problem with the sign of mass flow rate Enthalpy | behrang2009 | FLUENT | 0 | June 6, 2010 18:02 |
How to change from mass flow to volume flow rate | stanley | FLUENT | 1 | February 2, 2007 06:44 |
