help for ANSYS Fluent : cylindrical flow
Old   April 16, 2012, 10:24
Unhappy help for ANSYS Fluent : cylindrical flow
slim
slimmsk is on a distinguished road
Hello everyone,
I start a project to study digital and it's been 4 months since I started with ANSYS13 FLUENT.
I start by simulating the flow of blood through a vein with the presence of a probe (blood flow between two parallel cylinders) to validate my model.
The study is already done.
I can not find the correct profile (I found an acceleration along the cylinder) figure (A), the rate does not stabilize. The flow is along the Z axis
Normally I have to find a profile such that the figure (B)
The conditions I have are:
The vein is modeled by a straight cylinder of diameter D = 25.8mm and length L = 300mm. The probe is modeled by a right cylinder of diameter d = 3.1mm and the same length.
The flow area is S = pi (D ²-d ²) / 4 = 515.245mm ²
The flow is assumed laminar
The walls are assumed fixed and rigid over time.
The blood is assumed Newtonian studied with a density and viscosity 1050Kg/m3 0.0045Kg / (ms)
The temperature is set at 310 ° K (body temperature 37 ° C)
The boundary conditions are imposed
o Input: Q = 3600ml/min therefore a mass flow of 0.0633Kg / s
o Output: P = 399.96 Pa
I use the following configurations on fluent
Model: viscous laminar
Material: Fluid: Blood
Boundary condition: Massflowin =0.0633Kg/s
Pout =399.96Pa
slimmsk is offline   Reply With Quote
Old   April 16, 2012, 16:12
vlg
villager is on a distinguished road
Originally Posted by slimmsk View Post
[LEFT][LEFT]
[LEFT][LEFT] Pout =399.96Pa
oK, you set pressure outlet B.C, didn't you?
In case of constant density try to use velocity inlet instead mass flow inlet, as recommended 7.2.1 Using Flow Boundary Conditions
Since blood is Non-Newtonian liquid, you can use Herschel-Buckley, or Cross model for viscosity in Materials dialog.
villager is offline   Reply With Quote
ansys 13, blood flow, cylindrical flow, fluent
Fully developed temperature profile for laminar/turbulent flow in FLUENT raghu.tejaswi FLUENT 10 November 7, 2012 09:57
Different flow patterns in CFX and Fluent avi@lpsc CFX 6 April 17, 2012 01:22
Different flow patterns in CFX and Fluent avi@lpsc FLUENT 4 April 8, 2012 06:12
Two Phase Flow and Fluent Mach_v FLUENT 1 October 7, 2010 02:02
reversed flow in unsteady simulation with dynamic mesh (fluent 12.1) zhaoyu_001 FLUENT 0 April 7, 2010 00:24
