July 25, 2018, 11:32 |
i7 8700k vs E5-2690 v2
Ahmed Hafez
Rep Power: 7 |
I am going to get new computer to run Ansys fluent. There are two configuration which are nearly same price Configuration one: New Collection * Processor : i7-7800k (6 Cores/12 Thread - 3.7GHz Base Frequency/ 4.7GHz Turbo Frequency 12 MB cache dual channel with Memory Bandwidth:41.6 GB/s) * Ram: 2x16GB DDR4-2666 (or might DDR4-3200 MHz with overclocking) * Storage:250 SSD + 2TB HDD * No graphics card (gpu with processor will be used) Configuration two: Used Dell T3610 * Processor: E5-2690 v2 (10 Cores/20 Thread - 3.0 GHz Base Frequency/ 3.6 GHz Turbo Frequency- 25 MB cache quad channel with Memory Bandwidth:59.7 GB/s) * Ram: 4x8GB ECC DDR3-1866 * Storage:250 SSD + 2TB HDD * Graphics card: GTX 1030 Which one will be better in simulations? Thanks |
July 25, 2018, 19:39 |
Rep Power: 8 |
I would go with Xeon.
1) Quad Channel, more bendwidth 2) Graphics card for postprocessing. EDIT: flotus is more competent when it comes to hardware and I'd go with his advice Last edited by RedoFromStart; July 26, 2018 at 09:13. |
July 26, 2018, 06:54 |
Ahmed Hafez
Rep Power: 7 |
Thank you Redo
Is Bandwidth more important than core speed? |
July 26, 2018, 08:45 |
Alex
Rep Power: 47 |
They should perform about equally in parallel CFD, at least if you use fast memory for the I7.
The latter has the benefit of being much faster for lightly-threaded applications. I would only consider the older Xeon if it is significantly cheaper than the new platform. Just to clarify: we are talking about I7-8700k, not I7-7800x? |
July 27, 2018, 14:49 |
Ahmed Hafez
Rep Power: 7 |
thank you flotus
July 30, 2018, 14:58 |
One option is to go with a cheaper Coffee Lake CPU since you will be memory limited anyway. 8600k is a very reasonable choice (and with some mild overclocking it will match the 8700k in games as well). In fact, even the quad core 8350k is a reasonable choice, although it may be bad in many non-memory limited situations.
If you go cheaper CPU then you will be able to spend more on faster RAM. The scaling seems almost linear up to 3200 MHz. We have not had any reported results in the benchmarking thread with higher clocked memory, but I expect the scaling to continue since Coffee Lake @ 4.7 GHz is way too fast for dual channel memory. |
