March 21, 2022, 12:51 |
Suggestions for my work station
Klaus
Rep Power: 4 |
Hi
Please can you help me to suggest what can be better or what is wrong with this configuration, is this low end, medim or high end conifugration? HP Z840 2x Intel 12 cores, 3.2GHz 256 RAM DDR4 (8x32 or 16x16?) 512SSD + 3TB HDD Which graphic card will fit this configuration,what will happend if GB is to low? And does all card support all CFD, CAD softwares,do I need which softwares I will use? Last edited by Klaus M.; March 24, 2022 at 15:06. |
March 21, 2022, 15:28 |
#2 | |
Erik Andresen
Rep Power: 10 |
For cfd memory bandwidth is very important. The cpu you are looking at got a maximum memory bandwidth of 51.2 GB/s which was fine 10 years ago when the cpu was introduced. Today there are better options. Within the budget it is posible to buy a system with at least two alder lake cpus i.e. i7-12700 combined with DDR5 memory. With DDR5 @ 6000 the memory bandwidth is 96 GB/s for each cpu. DDR5 memory got ECC on the DIMM, but if EEC is very important all the way to the cpu you should find a motherboard with a W860 chipset. Supermicro has such a board named X13SAE. Though I have not seen it for sale anywhere yet. |
March 22, 2022, 06:20 |
Alex
Rep Power: 47 |
Again, I urge you to skim through the pinned thread here: General recommendations for CFD hardware [WIP]
We need as many answers as possible to the questions in chapter 0 in order to make useful recommendations. If some of the questions are irrelevant to your situation, just leave them blank. If you don't know the answer to some of the questions, let us know. Your questions regarding graphics cards are already covered in chapter 3. If you need clarification on something particular, just ask. Just to illustrate what happens if we don't have the information necessary to help you pick suitable hardware: Intels new Alder Lake CPUs are without a doubt the best desktop CPUs to date. But they can only handle a maximum of 128GB or RAM currently, and definitely not at DDR5-6000. And my general feeling so far is that you don't want to deal with the added complexity of building your own cluster from several PCs. |
March 22, 2022, 13:14 |
#4 | |
Klaus
Rep Power: 4 |
March 23, 2022, 15:30 |
#5 | ||||
Alex
Rep Power: 47 |
If someone mainly runs Fluent and has a licence for 8 threads, they need the fastest possible PC with 8 cores. Someone else might be running open source software without licensing constraints, and the "best" workstation for the same budget might have more, but slower cores. Or maybe there is a requirement for lots of memory. That disqualifies some of the mainstream platforms, because they only support 128GB maximum. Or the budget is fixed, but the PC has to be sourced new off the shelf from a large OEM: now the budget for the hardware itself is significantly reduced. Quote:
That's a pretty good starting point. I would recommend a dual-CPU setup, with Xeon E5 26xx CPUs from either the 3rd ("v3") or 4th("v3") generation, with 10-12 cores each. Any graphics card like a Quadro M4000, K5200 or upwards is fine. Ideally, you want 8GB of VRAM. All of this is assuming you need more than 128GB of RAM. Because if you don't, the suggestion from ErikAdr is very compelling. Since Alder Lake are the fastest single-core CPUs to date, they will be significantly faster for most things pre- and post-processing. Which is where you probably spend most of the time while learning how to use various software packages. Don't be mistaken though: if your CFD simulation doesn't fit into physical memory, it doesn't just run "a little slower". Even the fastest SSDs are orders of magnitude slower than system memory, which will translate to significantly lower solver performance. And quickly eat the write endurance of consumer-grade SSDs. Can't recommend. Concerning the question about graphics cards that is now deleted: Why do I recommend not over-spending on graphics cards, if lack of VRAM can prohibit you from doing post-processing on larger meshes? I can do post-processing of meshes with 400 million cells in Paraview just fine on my AMD RX570 8GB. I just have to pay attention on what I put on screen. It's a limitation you can usually work around, if you hit it at all. Quote:
March 23, 2022, 15:50 |
#6 | |
Klaus
Rep Power: 4 |
"Don't be mistaken though: if your CFD simulation doesn't fit into physical memory, it doesn't just run "a little slower" Physical memory you mean on RAM? If not enough what happend, program stop, softwear cant do job? Where I can see how much threads my software has and what are threads? From your answer I see that gaming Pc doing some process faster then w. station. I dont know what is pre and post processing and solver time, but I would be nice that computer solve task in less time/days. I target 256GB.. So if gaming Pc is option then other components I must look at? It seems @Ericadr suggest gaming components ,he say my CPU is too old / slow and for this money I can buy something better? |
March 23, 2022, 16:21 |
#7 | |||
Alex
Rep Power: 47 |
Commercial software like Fluent does not allow you to split these up arbitrarily. I.e, you can't opt to run 2 simulations on 4 cores each instead. Quote:
These tasks are often single-threaded or not very well parallelized. Which means that a CPU with fewer, but faster cores (like a modern desktop CPU) is faster. And let's not forget that you often sit there and wait for these tasks to finish, while you can just run a large simulation overnight. Solving: well...solving the simulation. Here "server" or "workstation" CPUs with more cores, and enough memory bandwidth to match, reign supreme. Provided we are not limited to a low core count from licenses. Post-processing: everything that happens after the simulation was run. generating colorful images to visualize the simulation results, using slices, iso-surfaces and the likes. Similar computing requirements as the pre-processing stage. Quote:
And due to the infancy of Alder Lake and DDR5 itself, you can't just run 128GB at DDR5-6000 speeds. At least not yet. So the 96GB/s figure is a bit optimistic. Long story short: the PC in your initial post will be slightly faster than a single alder Lake CPU for the solver phase. While supporting much more and much cheaper memory. |
March 23, 2022, 16:39 |
#8 | |||
Klaus
Rep Power: 4 |
Physical memory you mean on RAM? If not enough what happend, program stop, softwear cant do job? Solving or pre-processing is part when you leave your pc and go to sleep to do the work? |
March 23, 2022, 17:13 |
Sorry but I have to ask, do you have experience with cfd, fluid mechanics or numerical analysis ?
Softwares where you "scan" a complex geometry painlessly and wait for the results just does not exist. Setting up a simulation, and above all, getting useful results require many skills and a lot of work. |
March 23, 2022, 17:27 |
#10 | |||||
Alex
Rep Power: 47 |
If you are using the free student version, I think the limit is 4, but that may be outdated. But you are further limited to small mesh sizes. around 512k nodes if I recall correctly. Quote:
Operating systems extend that to virtual memory. The part that exceeds physical memory occupies an SSD or hard drive. You can configure that to be as large as you want, but you will be limited by the speed of that drive. For perspective let's just compare sequential speeds: CPUs have in the order of 50-200GB/s memory bandwidth. Even PCIe 4.0 NVMe SSDs only reach 7GB/s. Comparing latency, it doesn't get any more favorable. If you run out of physical memory, performance tanks. If you run out of virtual memory, the program crashes. Quote:
Maybe OP should first dip their toes into the water with the hardware that is used to write these posts. It would certainly help to make an informed decision later. |
March 24, 2022, 01:49 |
#11 | ||||
Klaus
Rep Power: 4 |
Hmm is this OK or must be OEM refabrish, is it safe to buy so expensive and old equpiment if they are used ? Quote:
March 24, 2022, 02:47 |
#12 |
Alex
Rep Power: 47 |
Had a long think about this whole situation. Please don't take it the wrong way:
I am having second thoughts about a total beginner buying a 3000€ PC. And me being complicit in that. You don't need that to learn how to use CFD. Start off small, get familiar with the software via tutorials and just doing stuff, see if it's for you. This can be done with pretty much any old computer you can get for 200€ on ebay. If you are not writing from a phone, you probably already have a capable enough PC to get started with learning. When you are more familiar with some of the concepts thrown around here, you can make a much more informed decision about what you actually need, before throwing a large sum of money at it. |
March 24, 2022, 04:13 |
#13 | |
Klaus
Rep Power: 4 |
my laptop to just open windows it take 15mintues so I dont do nothing at that 15 years old shit... Last edited by Klaus M.; March 24, 2022 at 09:58. |
March 24, 2022, 04:50 |
#14 | |
March 24, 2022, 07:45 |
#15 |
Alex
Rep Power: 47 |
See, I'm not even sure any more if these questions are genuine, or if I have fallen for a rather elaborate trolling attempt.
Jumping wildly between topics, opening just more and more questions with every single new post, and being super stingy about giving information yourself. Not to mention how we even got here. I'm out, sorry. |
March 24, 2022, 09:42 |
#16 | |
Klaus
Rep Power: 4 |
for the second time I try to configure PC and I am still nowhere, at the beginning. I am out too. |
January 24, 2023, 14:52 |
#17 |
Will Kernkamp
Rep Power: 12 |
March 24, 2022, 03:09 |
#18 | |
When I was a student I compiled a big cfd code on a 10inch notebook, that was enough to do some 2D cases and learned a lot with that. Number of cells in a simulation directly impacts the amount of RAM you need. A very rough estimate would be 1 million element needs 1 or 2 GB depending on the software and the equations solved. This is something you need to experience yourself in order to know what you will need on the hardware part. |
March 24, 2022, 03:33 |
#19 | |
Vestdam
Rep Power: 8 |
Base ANSYS CFD license allows 4 cores maximum. Buying an additional "HPC" license enables 8 more cores, so 12 maximum. After this, additional HPC licenses enables 32, 128, 512 etc. additional cores. |
March 24, 2022, 04:27 |
#20 |
Klaus
Rep Power: 4 |
Hm only 4 cores.
Does CX_Interpret_String work in parallel? | 86lolo | Fluent UDF and Scheme Programming | 2 | June 30, 2014 04:36 |
Companies that lease software & hardware for cloud-based work? | Catthan | ANSYS | 0 | June 18, 2014 10:53 |
Do all CFD analysts have to do some hands-on work except PhDs? | e13drd | Main CFD Forum | 2 | March 17, 2014 14:56 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
work station power needed | Greg | Main CFD Forum | 4 | September 16, 2008 03:29 |
