Home > Forums > General Forums > Lounge
Partition does not start on physical sector boundary!!??
Like Tree1Likes
  • 1 Post By wyldckat
Old   December 2, 2013, 15:21
Default Partition does not start on physical sector boundary!!??
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi
what does it mean?
Partition ... does not start on physical sector boundary
does it mean the partitioning have any problems?
ehsan@Ehsan:~$ sudo fdisk -l
[sudo] password for ehsan:
Disk /dev/sda: 2000.4 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders, total 3907029168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0xd41cd41c
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *          63   204796619   102398278+   7  HPFS/NTFS/exFAT
Partition 1 does not start on physical sector boundary.
/dev/sda2       409609305  3907007999  1748699347+   f  W95 Ext'd (LBA)
Partition 2 does not start on physical sector boundary.
/dev/sda4       204796620   409609304   102406342+   7  HPFS/NTFS/exFAT
Partition 4 does not start on physical sector boundary.
/dev/sda5       409609368   614389859   102390246    7  HPFS/NTFS/exFAT
/dev/sda6       614391808  1023981567   204794880   83  Linux
/dev/sda7      1023983163  1535990714   256003776    7  HPFS/NTFS/exFAT
Partition 7 does not start on physical sector boundary.
/dev/sda8      1535990778  2047998329   256003776    7  HPFS/NTFS/exFAT
Partition 8 does not start on physical sector boundary.
/dev/sda9      2047998393  2662404254   307202931    7  HPFS/NTFS/exFAT
Partition 9 does not start on physical sector boundary.
/dev/sda10     2662404318  3276810179   307202931    7  HPFS/NTFS/exFAT
Partition 10 does not start on physical sector boundary.
/dev/sda11     3276810181  3907007999   315098909+   7  HPFS/NTFS/exFAT
Partition 11 does not start on physical sector boundary.
Partition table entries are not in disk order
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   December 8, 2013, 15:04
Retired Super Moderator
Bruno Santos
Hi Ehsan,
I don't remember ever seeing such an error message from fdisk.
Nonetheless, a quick search online lead me to this answer: http://askubuntu.com/a/157000
If you're not able to see the page at that link, then the summary answer is simple:
Originally Posted by http://askubuntu.com/a/157000
This line explains the warning:
In theory this sort of partitioning may affect read/write IO rates somewhat, depending on your drive's firmware. If you are happy with the performance now, ignore the warning, and no need to do anything.
Best regards,
Bruno
immortality likes this.
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
How to partition cartesian grid for MPI in fortran CF Main CFD Forum 3 January 17, 2008 04:38
