Is my mass flow considered as balance?
Old   October 25, 2005, 02:15
Default Is my mass flow considered as balance?
MT
I've calculated the mass flow at inlet and outlet.
inlet=0.375433 kg/s outlet=-0.375963 kg/s
Difference is about 0.2%
Is that considered as satisfactory? Can I say the mass flow is conserved? Or I need to run a few more steps again?
Thanks.
Old   October 25, 2005, 09:25
Default Re: Is my mass flow considered as balance?
ganesh
Dear MT,
The definition of conservation tells us that mass_in = mass_out. The present case has difference in the 4th decimal, and looks okay, but if it is not a converged solution, you have to run your code till convergence. You could also check the mass flow difference on a coarser/finer grid compared to the present one, for a converged solution case and see if you get a larger/lesser difference comapred to the present. And more importantly, the conservation would reflect in the solution, as in the shock location if you deal with compressible flows.
Regards,
Ganesh
Old   October 25, 2005, 13:44
Mani
You will always observe a small error simply because of unwanted effects of artificial/numerical dissipation. Those effects are not accounted for in your mass balance. An error of 0.2% in a converged solution seems acceptable. If you're not happy with it, you can try to further reduce it by reducing artificial dissipation (or choosing a higher-order scheme). Just keep in mind, as ganesh pointed out, that the accuracy of your mass balance alone does not guarantee an accurate flow solution.
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 10:30
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 02:07
Net mass flow inlet vs outlet Nigui28 FLUENT 1 August 12, 2011 10:09
Mass Flow Rate student87 CFX 4 January 2, 2010 04:45
Determine mass flow rate along flow path Atit Koonsrisuk CFX 2 October 5, 2003 04:47
