April 29, 2012, 05:24 |
Turbulence intensity
Rep Power: 14 |
Hello community,
I do some simulations in an artificial homogeneous isotropic turbulence where k and eps are given. Does anyone know, how to calculate the turbulence intensity out of these values? Thanks so long. |
April 29, 2012, 07:29 |
You can just take a look at Fluent manual
6.2.2 determining the turbulence parameters Relationships between the turbulence quantities e.g. here http://jullio.pe.kr/fluent6.1/help/html/ug/node178.htm Truffaldino |
May 3, 2012, 04:27 |
Rep Power: 14 |
Thanks for that link. My problem is, that in a homogeneous isotropic turbulence the average fluid velocity is 0? That means I cannot calculate the turbulence intensity with the given formulas. Does anybody know, how to solve my problem. Or maybe I am wrong.
May 3, 2012, 10:53 |
Rep Power: 14 |
I am simulating particle collisions using a Lagrangian code. The fluent is just given by k and eps in the domain. The local fluid velocity for particle tracking is calculated using k and eps by a langevin dispersion model. For characterising the turbulence I want to give the turbulence intensity.
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
Question on Turbulence Intensity | Eric | FLUENT | 1 | March 7, 2012 04:30 |
About Turbulence Intensity (Pipe flow assimilated) | gRomK13 | Main CFD Forum | 1 | July 10, 2009 03:11 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
